recurring fluid leak on drivers side tire
Old Aug 7, 2018 | 10:30 AM
ybakos123's Avatar
Hi Freaks,
Does anyone know what might be causing these drip leak marks to appear on my drivers side front tire? Started happening about a year ago. Thought it could be a leaking break line, but I asked the service folks about it and they said it could be water from the AC. But it appears overnight after I've driven the car without the AC on at all. Photo attached.
Old Aug 7, 2018 | 01:31 PM
2Rismo2's Avatar
Dog piss...
Old Aug 7, 2018 | 01:34 PM
evilchargerfan's Avatar
does it smell like dog piss?
Old Aug 7, 2018 | 01:36 PM
yuk.. i’ll take bee crap over dat any day. lol
Old Aug 7, 2018 | 03:09 PM
Alco RS-1's Avatar
Check the inside of the tire. I once had an old car that had a leaking shock that dripped oil on the inside of the tire.
If you dismount it, can you hear or feel sloshing inside?
Old Aug 7, 2018 | 05:36 PM
knope's Avatar
why did you fill the tire with water?!?
Old Aug 7, 2018 | 06:49 PM
Uncle Gary's Avatar
Post #2 nails it. A neighborhood dog has claimed your Fit as his territory.
Old Aug 7, 2018 | 07:28 PM
perhaps you and the op from another thread, could share ideas and find a way to fend off dogs and reclaim that wheel as your own territory
"how do you keep dogs away from your car"
https://www.fitfreak.net/forums/gene...-your-car.html
Old Aug 7, 2018 | 08:30 PM
wasserball's Avatar
It does look like the liquid is coming from inside the tire. Moisture from the air pumps at the gas stations? But, then the tire is sealed to the wheel so I doubt water is seeping out from there. It took you about a year to be concerned?
Old Aug 8, 2018 | 10:33 AM
vinylengraver's Avatar
This is clearly the expensive Nitrogen they filled your tires with seeping out and reacting with oxygen in the air creating water as a result.
You should go back and give them heck for selling you Nitrogen that can"t stay where it belongs.
If you lick it and it tastes slightly acidic, it's Nitrogen for sure.
Old Aug 8, 2018 | 11:05 AM
2Rismo2's Avatar
Old Aug 8, 2018 | 12:06 PM
woof's Avatar
The fix is rather easy. Carefully wash off all traces of the offending liquid. Then standing in front of the tire pull down your zipper and, uh, mark the tire as yours again. The chances are that the dog won't accept this the first time around and you may have to repeat this several times. You might want to check around your yard to see if there are any other objects like trees which the dog is trying to steal from you and follow the reclaiming process to correct the situation. To avoid awkwardness with the neighbors make sure that when you do this that there is nobody else about, and no neighborhood security cams (think of YouTube!) pointed in your direction.
Old Aug 8, 2018 | 01:17 PM
Or better yet, fill a container in the comfort of your washroom , transfer the contents to a spray bottle, apply as needed to affected area(s) and keep in the fridge between applications to preserve freshness.
Make sure to clearly mark the spray bottle with a permanent pen (sharpie will work) to prevent unintended use.
Old Aug 8, 2018 | 02:04 PM
if u need dog control use white vinegar. it works for keeping dogs and it’s pets aka midwestern middle aged fat woman out of my yard.
Old Aug 8, 2018 | 03:07 PM
did anyone notice a guy named "WOOF" is telling our OP to pee on his car?
*chuckle*
Old Aug 13, 2018 | 01:05 PM
Howie_Feltersnatch's Avatar
your local Hobo owns that wheel now.
Fit FX
Apr 12, 2025 07:55 PM
Silvermelon19
Jun 24, 2019 10:44 PM
Myxalplyx
Oct 31, 2014 12:07 PM
GTRPLYR
Apr 23, 2013 05:25 PM
