Snow tires and rims (sizes)
Old Sep 15, 2018 | 09:10 AM
stephenmarklay's Avatar
I am thinking about getting a smaller rim for my winter set of tires/wheels this year. My job requires a lot of driving and that includes some mountain passes. With the bad pot holes that develop I want a bit more sidewall.
How small of a rim will fit? The rotors look pretty small so I am sure a 15” is fine and perhaps even a 14”?
Thoughts?
Old Sep 15, 2018 | 12:01 PM
sneefy's Avatar
Did you search the forum? There are a lot of threads answering this question.
That said, I run 14" steelies in winter from Tire Rack with 185/70-14 tires. The extra sidewall is indeed a good thing. Just pick a good tire. I tend to prefer Michelin or Nokian winter tires.
Old Sep 15, 2018 | 04:17 PM
kanadary's Avatar
I used the 15 inch of rims, believe that other honda models share the same rim so there may be some at junk yards. I run nokians and it's great
Old Sep 15, 2018 | 06:26 PM
Thank you both.
Old Sep 17, 2018 | 04:47 PM
Howie_Feltersnatch's Avatar
14" with the General Altimax Artics have always served me well, going on my 4th season. Coming from a AWD to low FWD i was impressed on how well the pull thru the slop and snow in the Midwest. Most days I can go with out the TC kicking in, but on really bad days I turn it off if I'm in stop and go or need to pull out and get up to speed quickly.
Old Sep 18, 2018 | 07:58 AM
Thanks Howie… I was looking at those. That tire and the smaller size is more economical too. Does anyone have the offset handy? I would like to get some steel wheels with the proper offset.
EDIT: I found it under the wheel section. +53
Old Sep 18, 2018 | 09:49 AM
sneefy's Avatar
14" steel wheels need to be about a +45 offset to clear brakes. That's what mine are.
Regarding the Altimax Arctic, they have a good reputation of bang for the buck. But most studdless winter tires will outperform studdable unless you actually run studs.
Old Sep 18, 2018 | 06:25 PM
Rob H's Avatar
I bought based on the glowing reviews on forums. I will never buy again. Last year I took my 1/2 worn Blizzak and gave them to my son and purchased the Alitimax. The 1/2 worn Blizzak are way better in the snow. I thought it was my imagination until I did my own feel of the pants test. My wheels and my sons share the same bolt pattern. I ran my Alitmax in a fresh snow and then came home and switched wheels with my sons car. Maybe 30 minutes of time difference. I'm confident the 1/2 worn Blizzak were way better. That being said, the worst snow tire is way better than any all season tire in the snow.
Old Sep 18, 2018 | 07:53 PM
woof's Avatar
I bought Arctic Altimax 12 tires last year ( all 4 studded) and they were fine for what I mostly experience here - slippery roads with ice and packed snow. Pure snow traction isn't really an issue for me and in fact last year we really didn't get much snow so I don't know how they'd perform in heavy snow. I think I'd be worried more about the low clearance underneath the Fit with a deep snowfall. I do suspect though that if I wasn't for the studs I'd probably look around a bit at other tires like Michelin and Pirelli - but maybe in the end still have stayed with the Altimax though because they're such good value, I don't know.
Tires I really wanted were Nokian Hakkapeliitta 8 (studded) but one tire chain has a monopoly on them in this region and you know what that means ($$$) so I gave them a pass.
Old Sep 19, 2018 | 07:33 AM
Thanks for the info guys.
Old Sep 19, 2018 | 08:13 AM
sneefy's Avatar
Michelin is doing their normal seasonal $70 rebate right now. For two more days. Tire Rack is also offering free shipping on orders over $50.
Old Sep 19, 2018 | 10:01 AM
I just did the package deal from Tire Rack- Mounted/Balanced delivered for sub $500.00
Old Sep 19, 2018 | 02:26 PM
Odie's Avatar
The Arctic 12s' replace the Arctic . The 12s' siping depth is less than the Arctic . The Arctic start at 11 or 12 and the 12s' maybe a 1/3 of that .
Ryu69
Apr 24, 2024 09:33 AM
Acid Jay
Jan 22, 2012 11:19 PM
jcschlic
Nov 17, 2010 10:48 AM
FitFieFoeFum
Jan 15, 2009 01:08 PM
Xaositek
Dec 30, 2007 11:51 AM
