Has anyone tried 5-Lug HRV Swap?
Old Jan 4, 2019 | 08:23 PM
Alvin Thai's Avatar
As the title states. Has anyone experimented with the interchange ability of the HRV parts with the GK chassis?
I know the GK chassis uses the same chassis so it could be very compatible. I wonder if the disk brakes would swap over as well.I have found 5 lug conversions for the GE platform. I wonder if these will work as well.
FIT 2nd 5LUG CONVERSION KIT USDM SPORT
https://www.fitfreak.net/forums/gaug...n-hubs-ge.html
I did look into the part diagrams and a lot of pieces seem to match up. Little off topic, but the AWD rear subframe looks like it could be compatible as well, but I don't know what transmission would take it.
Old Jan 4, 2019 | 09:23 PM
There are not really any benefits to a five lug setup in Fit sizing.
Old Jan 4, 2019 | 09:30 PM
Alvin Thai's Avatar
exactly why I’m looking into it. For my specific needs
Old Jan 7, 2019 | 03:37 PM
What are your specific needs? Just curious.
Old Jan 7, 2019 | 04:36 PM
Alvin Thai's Avatar
I work for a company that manufactures and produces hundreds of wheels a year. The 4x100 market is not something we target so if I switch to 5 lug I can regularly swap wheels and promote them with photography and marking. It's also extra income for me whenever I swap/sell a set.
Old Jan 7, 2019 | 06:58 PM
fujisawa's Avatar
Lol that is specific, yes.
I believe you could probably swap them, but you better not take the word of some random guy on the internet. Check parts numbers of pieces that look like they should be the same. If they are, and there are enough of those touching the part you want to swap out, and any info you can find on dimensions or bolt sizes match, then it is a good guess it'll work.
Rear discs would be a benefit, but typical swaps like that need a new brake proportioning valve and you'll be the first to discover what else needs to be addressed.
The benefit, should you do this, is that your car will stand out as unique during the shows you mention. Is it going to be easier or cheaper than swapping the entire car, that's your question there...
Old Jan 7, 2019 | 07:01 PM
fujisawa's Avatar
Also I just looked at the link you posted. That seems to me like the easier option considering your focus is looks and not performance
Old Jan 8, 2019 | 12:28 AM
Alvin Thai's Avatar
thats a good tip to look at part numbers of surrounding parts didn’t even think of that.
as per cheaper to buy another car? The fit is paid off, gets 40mpg, and requires no maintenance. Hubs from a junk yard cost a 400-600 dollars. So technically no it’s not cheaper to buy a cool old school show car that breaks down all the time lol. Been there many times.
Old Jan 8, 2019 | 09:48 AM
Rob H's Avatar
Why don't you just re-drill the stock hubs to 5x100? Any competent machine shop should be able to do it.
Old Jan 8, 2019 | 07:30 PM
fujisawa's Avatar
I meant swap in a whole HRV, not just some of the parts.
But if you are going to do all your work and the cost is only $600, then clearly you're right about the cost.
Mbp604
Jun 19, 2018 01:01 PM
xxryu139xx
Mar 13, 2015 07:35 PM
Orcshine101
Sep 7, 2014 01:40 AM
Orcshine101
Sep 2, 2014 12:49 AM
Goobers
Mar 31, 2014 02:47 AM
