Ac compressor
Old Apr 11, 2019 | 08:23 PM
BigSpark's Avatar
Ac compressor
Does anybody know offhand, down to what temperature the AC compressor will run?
Old Apr 11, 2019 | 09:17 PM
BigSpark's Avatar
Ac compressor
Old Apr 11, 2019 | 10:32 PM
woof's Avatar
The AC compressor has to compress Freon™ gas and turn it into a liquid. I believe that happens at about -40° C, a bit more or a bit less depending on the type of Freon™.
Old Apr 11, 2019 | 10:56 PM
BigSpark's Avatar
I'm still a bit confused because -40 Celsius or Fahrenheit is actually the same so I'm going to speak in terms of Fahrenheit if its -40 Fahrenheit that the compressor will operate until that doesn't seem to make sense to me I know I'm previous vehicles if the outside air temperature was somewhere in the neighborhood of a little above freezing say 35 degrees you could turn the air conditioning on inside the car but the compressor would not engage because of the outside air temperature already being cold.
Old Apr 11, 2019 | 11:41 PM
woof's Avatar
The compressor could be damaged if the A/C system is turned on when the air temperature is too low (I suppose the Freon might solidify rather than liquefying, damaging the pumping system) therefore it is reasonable to assume that the manufacturer has a safety feature built in to disable the system when air temperatures are too low. That would be my assumption.
Old May 7, 2021 | 03:42 PM
Dougfit's Avatar
I know this post is old but I just recharged mine using a can of A/C Pro Ultra. Super simple since the port is right there on the Fit, took 5 minutes. My system was very low on the gauge. Filled it up and now it blows really cold air.
I got it at Advance with a promotion of 15% and $5 off for signing up for rewards so even with tax it was just $40.
Did not even use the full can. It says it reduces leaks but even once a year fill who cares. Hope that helps someone.
phybere
May 29, 2018 11:46 PM
taxonomy
Jun 17, 2017 10:08 PM
Austinite
Jul 4, 2015 01:42 PM
Chairman Kaga
Apr 11, 2011 11:39 AM
mega56
Apr 12, 2009 11:22 PM
