3rd Generation GK Specific DIY: Repair & Maintenance Sub-ForumThreads discussing repairs and maintenance you can do yourself on the 3rd generation Honda Fit (GK)
I am getting ready to do a first oil change on my 2018 Honda Fit Sport.
I was thinking about buying a set of the Rhino Gear Ramps (#11909). They have a specified 17 degree incline which is slightly greater than the 15.7 degree maximum that I calculated. It could be that the short incline distance of these ramps avoids any problem.
I'd like to know if anyone has had good luck with these.
I did see the owner of an older Fit note that he used a piece of wood to protect the bumper from contacting the ramp.
I am also not sure if the clearance is any lower on the Sport trim level.
If you leave the undercover off (no negative comment please), you can reach the drain plug and the oil filter without a ramp. It takes me about 15 minutes to change the oil/filter. Release the oil filler cap will help draining the oil faster.
My GE conflicts with the rhino ramp a little bit. Having had other low slung cars this does not bother me and i highly recommend them. If you shim them with a thin piece of wood you can make them work no problem.
I use the rhino ramps for my oil changes. I was bothered by the clearance on my 2018 and used a piece of wood to improve it. The car is just a little bit too low as is.
I have a harbor freight plastic ramps and they work fine with my 2015. If you need some additional clearance just take some short 2x4s to drive up on before getting to the ramps.
I've never tried changing the oil without it on ramps. My oil pan is pretty tall so don't think it'd fit under the car at all lol. I think it holds something like 16 qts haha
so using ramps can work? the only thing i am concerned is that if you have ramps, the car is slanted.... wouldn't this cause engine oil not to fully get drained?
If you lift the front wheels up the car is slanted in the right direction because the drain plug is towards the back of the block and lifting the front up sends the oil rushing towards that drain plug at the back. Keep that in mind when you position the drain pan you're using the oil won't be falling straight down - it will initially shoot out horizontally several inches or more towards the back of the car. You'll see
I mean maybe if you are foolish and leave them in the sun. Know your materials limitations, plastic doesn't like UV or temp extremes. I keep mine indoors for that reason.
Complain if you like but metal ramps have their own downsides, cost and weight mostly.
yes, cost and weight disadvantage is why i was looking at rhino ramps. now that i know having only front of vehicle will still allow engine oil to full drain, i will proabaly get one soon.
Metal ramps have also bent so they're not perfect.
2ris, great point. Dad bent one once.
Evilc, cool find. 2.5in doesn't gain you a ton of extra room to work though! Wonder if they are meant for people who need extra clearance to get a jack under.
