Electrical problems after reversed polarity jumpstart
Old Aug 13, 2019 | 12:01 AM
stdout's Avatar
Hi there. I have a 2015 Fit LX with AT. I reversed polarity jumpstarting it and now some of the smart electrical things don't work. Here are some of them:
- Cruise Control state resets when I turn off the ignition. I usually leave it in Main On state (press the Main button on the steering wheel) at all times and just press Set when I actually need CC. Now I have to press the Main button every time before Set.
- Headlight's Auto mode doesn't work (lights go dark).
- Central locking system (the buttons on the drivers side door that lock/unlock all doors) doesn't work unless the ignition is on.
- Remote key doesn't work (the small led is flashing when I press buttons on the keyfob but nothing happens, the car won't lock/unlock)
- Power Windows buttons don't work unless the ignition is on.
- The stereo didn't work but I was able to fix that by replacing a blown fuse.
Everything else seems fine, the car runs, turn signals/lights/stoplights work.
I have a new battery now, checked all fuses (Box A under the hood, Boxes A and B under the dash on the driver's side). Only one was blown (the car stereo).
What else can I check to narrow down the problem?
Can I fix this without special tools?
Old Sep 24, 2020 | 12:49 PM
timpmeister's Avatar
I know this thread is a year old, but I have the same exact problem: I had to have the car jumpstarted, and afterward, nothing except the basic necessities work (except while the engine is on). The clock resets to 1:00 every time I start the car. No interior lights to speak of, no stereo/bluetooth/hands-free phone, etc. No remote entry, nothing that I consider a "feature". Heck, even the diagnostic reader circuit is dead!
I checked most of the fuses in Box A under the hood; all of those I checked were OK. Where is the stereo fuse located? I would like to have that back above all else.
Old Sep 24, 2020 | 01:10 PM
stdout's Avatar
I ended up taking it to a dealership. This is what they've put in the service records
.. found 10amp fuse in underhood fuse box in wrong position #28 should be in position #29. Correct and confirm now working.
I hope that helps.
ksmith0034
May 29, 2022 10:46 PM
hoopmatch
Sep 26, 2020 10:22 PM
AnalogDog
May 3, 2017 12:53 PM
gfrobe
Jun 6, 2012 01:29 PM
canuck901
Mar 23, 2010 10:25 PM
