how to adjust headlights?
Old Dec 30, 2015 | 07:21 AM
bach's Avatar
Anyone know how to adjust the headlight angle on the GK5? It's been bugging me for a while now, I think the angle is too low. There is a spot just outside town where the road goes downhill and it's really bad; last night I nearly hit a forest creature because I didn't see it until it was right in front of me. Just for kicks I went back there with the other cars (2010 Corolla, 2008 XB2) and realized how much higher both those headlights are aimed. This seems to be a persistent problem with Fits in general, according to my research.
I'm not looking for a lecture or anything, I just want to fit the screw or whatever to raise the headlight line a few degrees.
Old Dec 30, 2015 | 10:40 AM
stembridge's Avatar
I agree about the upper cutoff being to aggressive on the Fit. If there was even less of an abrupt change from "light" to "dark," it would help a ton. It's borderline unsafe at times as-is. I'll have to poke around underhood and see if I can locate an adjustment screw.
es
Old Dec 30, 2015 | 01:30 PM
GKfit's Avatar
The adjustment screw (silver) is on the top side of the headlight housing. Use a philips screwdriver or a 10mm wrench.
Old Dec 30, 2015 | 01:58 PM
bach's Avatar
Thank you! I'm sure only a few degrees will do it. My car has that front-end sag and though mine is not as severe as others, I'm wondering now if the sag has anything to do with my headlight problem.
Old Dec 30, 2015 | 05:35 PM
Uncle Gary's Avatar
Bumper "sag" won't have anything to do with your headlamp aim, as the headlamps are not attached to the bumper cover.
Old Jan 6, 2016 | 04:37 PM
Belch's Avatar
I just noticed last night that mine has an automatic headlight adjuster. I assume it's for low speed fog driving, but I thought I'd chime in on this topic because I'd never seen anything like that before. Drove for an hour with my headlights adjusted as far down as possible (three way switch located next to the button that disables the anti-skid brake controller) and thinking that this can't be right.
Old Jan 7, 2016 | 03:56 AM
DWils's Avatar
Fits have automatic headlight adjusters now?!
Old Jan 7, 2016 | 06:20 AM
TxTom's Avatar
Apparently those in Japan have that feature.
Old Jan 11, 2016 | 10:24 PM
Kmac66's Avatar
Which way do you trn the screw to move te lights up? Clockwise or outer clockwise?
Old Jan 12, 2016 | 05:02 AM
TxTom's Avatar
CORRECTION: On my '16 EX-L Nav, I used a wrench on the left headlight to raise the light counter clockwise, as you stand in front and are looking at the car. And ALSO counterclockwise for the right front headlight, standing and looking the same way. Took quite a few turns. I do notice a difference. (My previous info was incorrect stating "clockwise," re the right headlight)
Old Jan 15, 2016 | 02:24 PM
TxTom's Avatar
oman
Dec 21, 2017 10:10 PM
Super Mario
Jul 6, 2015 06:56 PM
Crawly
Apr 7, 2009 08:25 AM
FELIXY69
Jan 7, 2008 03:42 PM
FikseRxSeven
Aug 19, 2006 09:45 AM
