Sony XM-S400D Power
Old Aug 4, 2019 | 12:11 AM
bim27142's Avatar
Sony XM-S400D Power
Hi Guys,
So, I decided to upgrade my 2016 GK's head unit (Pioneer Z5050) and speakers (Infinity Reference 6530 - front / 6532 - rear). While I think it's OK to run it solely using the HU's power output, along the way I plan to throw in a small amp (Sony XM-S400D).
My goal is to make it as clean and as OEM look as possible so I plan to tuck this in under the dash and as per Crutchfield, I may be able to wire this directly from the radio power harness, but just to be (more) safe, I should be able to just use fuse tap on this to at least 15A non critical (existing or vacant) fuse slot in the fuse box under my dash right? So I won't have to wire it directly going to the battery.
Also already took care of the harnesses needed to make it as plug n play (and as OEM) as possible.
Appreciate any thoughts on this.
Thanks!
Old Aug 5, 2019 | 11:55 AM
Action Jackson's Avatar
For any type of amplifier, it is much safer to wire to the battery for power and fuse it properly.
Old Aug 5, 2019 | 05:03 PM
GolNat's Avatar
For an amp I always run a dedicated power wire (with fuse) to the battery.
Old Aug 16, 2019 | 02:35 AM
bim27142's Avatar
Thanks guys for all your responses.
I saw a video on Youtube form Dabinche and he wired his under the dash fuse box but directly to the battery line input (don't know how to describe it) and not from the fuse slots.
However, my Jazz did not have the same style of fuse box as his as mine is covered (the battery line input) so not sure if I can access it without breaking the plastic covering.
Old Aug 16, 2019 | 09:13 AM
For a dash cam, that would be ok. Don't wire your audio system that way.
RavenManiac
Dec 28, 2017 12:58 PM
MarcoM
Jan 5, 2011 08:23 PM
saintcajun
Jul 19, 2009 01:42 AM
Tigerman50
Dec 15, 2008 10:14 PM
Crawly
Sep 12, 2007 09:41 AM
