Aftermarket for 2017 AU model
Old Aug 4, 2019 | 09:19 PM
ffun09's Avatar
Hi,
I am after some more info on the 2017 model Jazz/ Fit VTi-S.
Having done a bit of research, I have discovered
- The physical connector is different from most available
- The wiring colours are also different.
There is also an 8 pin connector that seems to be for the camera.
Does anyone have the original wiring diagrams for this car.
Old Aug 6, 2019 | 07:24 PM
ffun09's Avatar
Camera wiring
Initial pic of 8P conndctor
Old Aug 11, 2019 | 04:11 AM
ffun09's Avatar
Update for this weekend
Working components :
Power
Speakers
Park brake switch
Reverse Sense
Paritally working :
Steering Control
Not working :
Rear Camera
The steering wheel controls can be seen to operation :
When the old head unit was plugged in the voltage varied depending on the button.
When not plugged in I get a varying resistance between the signal wire (Pink pin 5) and what I
gather is remote ground (White pin 20)
Head deck is Kenwood DMX 8019S
According this Kenwood info it should just work.
https://www.kenwood.com/nz/car/visual_navigation/oem/
Does anyone have any trick to making it work?
RealestFit
Aug 13, 2019 07:43 PM
mtoy1204
May 21, 2017 07:03 PM
iggy
May 8, 2017 09:57 AM
KikeDiaz
Jan 13, 2017 01:48 AM
2015FIT
Feb 9, 2016 05:15 PM
