Cord Kit for iPhone
Old Aug 17, 2014 | 10:15 AM
Dann-O's Avatar
Cord Kit for iPhone
So I'm getting HondaLink set up so I can use my iPhone maps app, and Honda would like to sell me a cord kit for $99. Seems like a bit much. Is there a cheaper source for the kits or a source for the individual components?
I have 1500 miles on the EX manual and really like it so far.
Old Aug 17, 2014 | 10:19 AM
Mike Houser's Avatar
Someone on another thread posted..amazon has the individual parts much cheaper
Old Aug 17, 2014 | 12:31 PM
JupiterJoe's Avatar
Also note, you can't use Apple's Maps App -- you can only use Honda's NAV app found in the Apple App Store for $60 --- you may want to check the reviews before buying...
Old Aug 17, 2014 | 12:56 PM
tmfit's Avatar
The advantage of buying the cords from apple is they are both the same length. I couldn't find an HDMI cable short enough to not have to coil it up. Honestly after having it for a couple months I seldom use it. The navi app isnt near as nice as a garmin.
Old Aug 17, 2014 | 01:17 PM
15BlkPrl's Avatar
I bit the bullet and purchased the kit individually from the Apple store. Was $86 dollars total. Not bad for OEM stuff from Apple. As for the Nav App in a word it FRACKEN SUCKS!!!!! Do not buy it your better off following the stars, use a sextant or just plain getting lost.....
Old Aug 17, 2014 | 05:14 PM
GeorgeL's Avatar
It's an interesting problem for Honda. The nav app that they are linking to can't be too good or they will undermine sales of their own navigation system.
Having a rudimentary nav app boosts sales of the Display Audio system to people too cheap to buy Navi and who might gain the mistaken impression that they will be getting Apple or Google navigation on the big screen. Honda isn't too quick to correct this mistaken impression. The proof is in the lack of pudding.
Tmfit has it right, a low-end Garmin is better than the Honda nav app.
Old Aug 17, 2014 | 05:29 PM
ArchaicAP2's Avatar
I was under the impression the honda has a mirroring feature that will show what's on your phone. Like if you were to use apple maps. Or is this something that will show up later.
Old Aug 17, 2014 | 05:56 PM
JupiterJoe's Avatar
The Display does have a mirroring feature - but it only works with the car in Park... once you are moving the display is disabled - and there is no real work around - at least not without a lot of dismantling of the Head Unit and re-wiring work. Hopefully, at some point - we will see a CarPlay update????
Old Oct 16, 2014 | 04:53 PM
JKDVT's Avatar
So if you set your destination on the iPhone nav app while the car is parked, it won't mirror on the display when you're moving? What about audio controls (i.e. playing audio through the speakers?
Old Oct 16, 2014 | 05:12 PM
JupiterJoe's Avatar
The audio directions from an iPhone app such as Google Maps or Apple Maps should play through the audio on the speakers - you just won't have any video displayed on the HondaLink display...
Old Oct 16, 2014 | 05:14 PM
JKDVT's Avatar
Wow. That's annoying. It looks like I'll be back to command hooks (my rental car solution) until the Honda apps work better or CarPlay is available.
Old Oct 16, 2014 | 09:05 PM
stembridge's Avatar
I bought the HDMI adapter from Apple, and was able to find a 6" HDMI cable as well as a 6" USB->Lightning cable online. Plug the adapter into your iPhone and the other two into the HDMI and USB ports and you're good to go without a snarl of cables. The only down side is that if you need to actually do something on the phone, you only have about 12" of total cable length.
I noticed that the HondaLink Connect app got updated a couple days ago, which should hopefully fix the iOS 8 incompatibility.
es
Old Oct 16, 2014 | 10:48 PM
JKDVT's Avatar
Have you tried updating the HondaLink Connect app? If so, how does it work? The few reviews I read on iTunes were not promising...
Old Oct 17, 2014 | 10:47 AM
stembridge's Avatar
I updated the app, but haven't tried using it yet. Not sure if I want to only up for the Nav app based on what I'm reading about it.
es
Old Oct 17, 2014 | 12:17 PM
JettBlackFit's Avatar
I did the update and have to say it's much better. I have an iphone 6 and it seems to be fine. I do not have the Nav app, I think this needs work. All the other features work well.
Old Oct 19, 2014 | 05:32 PM
JKDVT's Avatar
JettBalckFit, out of curiousity, by "much better," do you mean, "it pretty much works as expected, but with glitches"? (and if so, what glitches), or "it pretty much works as expected/described."?
TallguyNB
Nov 12, 2015 11:16 AM
prettyhatem
27
Apr 25, 2015 05:50 PM
wxgeek
Mar 27, 2015 05:35 PM
oman
Nov 7, 2014 01:47 PM
SR45
Mar 24, 2014 11:01 PM
