2018 Add an Amp wiring harness
Old Jun 1, 2018 | 07:53 PM
ndtemple417's Avatar
Anyone know where I can purchase a a add a amp wiring harness to add to the stock head unit on a 2018 honda fit ex? Any help is appreciated.
Old Jun 3, 2018 | 05:33 AM
Action Jackson's Avatar
Trust me on this, you really only want to do it once. Not 3 times like me!
Depending on your (future) needs, Amazon has a nice 4 gauge OFC kit by Knuconcept, and yes I do have that one.
Or you can go with a 0 gauge dual amp kit, if you plan on going that route.
You need to assess your current needs, plan many times including any future needs, and try to spend once.
Look up the threads in the ICE section if you want to keep your stock headunit to retain rear and side cameras.
Might as well upgrade speaker wiring too.
And even though I did it as a last step, sound proofing/damping the car should be considered as it makes a huge difference to sound and driving quality.
Old Jun 3, 2018 | 08:31 AM
Yep I actually have the Knuconceptz in my old fit, this is a work car. I was actually referring to something like this (
Amazon Amazon
). Since it's a work car I can't really do any sound damping, but my boss/owner is cool with me adding the amp and sub like i did on my old fit.
Old Jun 3, 2018 | 09:58 AM
Cool, I've never seen an all in one like this for the GK5's before.
Old Jul 12, 2018 | 07:25 AM
UnFitRick's Avatar
Looking for the same thing for my 2019; what did you end up using?
Old Jul 12, 2018 | 08:38 AM
Bassguitarist1985's Avatar
You will have to make it from various parts. To my knowledge no company has made a harness to retain the steering wheel controls and allow for external amps/processors. Check out my thread!
Old Jul 13, 2018 | 07:08 PM
UnFitRick's Avatar
I read your dissertation; it was very impressive. I understand that your system is electrical, but doesn't it take a nuclear reaction to generate the 1.21 gigawatts needed to make it work?
Old Jul 13, 2018 | 07:59 PM
Fair enough! There is a post that has the exact pinout of all the wires and the ones you need to add. Should be clarified with that one post I hope!
However, the link above will work perfectly for the GK. It has the outputs for the sub only, but buying that harness, then cutting into it to get the L/R outputs for both the front/rear to add your external amp and processor should you so choose. Honestly if they had that harness when I did my setup would have saved me hours of research and fabrication! $20 is well worth it!
Old Jul 13, 2018 | 08:39 PM
UnFitRick's Avatar
Thank you for the added edit. And thank you for understanding my (lighthearted) sarcasm. All I am looking to do is install a powered sub, throw some bass blockers on the factory speakers (maybe replace the fronts with an inexpensive component set), and call it a day. If the interface harness referenced above will work on a 2019 Fit Sport, you are absolutely right: it will be perfect. I will check it out; what is your level of confidence that it is the right piece? Thanks again for your help.
Old Jul 13, 2018 | 10:32 PM
I'm 99% sure it will work. Despite the remodel of the generation, its doubtful they would change the pinout of the connector. Not all pins are used anyways for the HU. In any event please do let us know how it turns out. Start a thread if need be!
Old Jul 15, 2018 | 11:44 AM
payluder's Avatar
Axxis makes the steering wheel control and amp/processor retaining. It can also retain the back up camera and lane watch
Old Jul 15, 2018 | 03:37 PM
Yeah, someone already posted about this kit, and while it does what it says, the delay in activation of the lanewatch camera and the fisheye angle it has makes it less than ideal, almost unusable.
ieandro
Jul 3, 2021 10:56 PM
LilPuttputt
15
May 6, 2019 11:22 PM
orangeSloth5
16
Aug 31, 2018 09:15 PM
FyrFytr
Apr 10, 2012 12:46 PM
specboy
Oct 19, 2009 07:42 AM
