ToddF's '16 yellow LX
Old Apr 21, 2020 | 08:37 AM
  #101
ToddF's Avatar
I had replaced the ceiling interior incandescent light bulb with a
purple LED version purple LED version
Over time these proved to be less than satisfactory. In the summer the light fixture gets rather hot in the Virginia sun, and the LEDs would fail over time. I was needing to replace the ceiling LEDs around 1 or 2 times a year as they flickered and died. I got tired of this, so I found an
alternative LED alternative LED
I thought might work better.
I had always thought the old ceiling light was a little dim, and decided to step it up a little. In addition to the one in the existing bulb socket I decided to add more in the ceiling recess. I started the process by taking cutting up an empty kleenex box to get a piece of thin cardboard. I trimmed the cardboard to fit into the ceiling recess around the LED in the stock socket. Then I covered the cardboard with aluminum tape to increase the reflectivity of the inside of the socket. Next I used 2 part epoxy to glue three more of the LED "bulbs" to the backer.
Next came the wiring. To do this, you need to use a power supply to check the polarity of the lights, as they won't light if they are connected backwards. I wired them together using some 22 gauge silicone insulated wire I use for building light sabers. I cut a couple contacts from brass shim stock to use to connect to the contacts in the stock socket.
Next, I installed the new lights in the ceiling recess. I slid the brass contacts into the stock socket so they were pinched between the socket wiper contacts and the new LED light installed in the socket.
Here's what it looks like when it's fired up. 24 LED dies worth of purpley photons.
With the diffuser lens replaced, the ceiling light now illuminates the entire cabin. Way brighter than it was before.
Old Apr 21, 2020 | 09:10 AM
  #102
ToddF's Avatar
Ever since I started modding this car I've wanted to upgrade the headlights and tail lights. Even though there were some really cool designs out there, I could never bring myself to pay the high price for replacement units. I hadn't see what was out there for a couple years, but recently did a new search and found a new design I really liked, and found one on ebay for a slightly lower price. So I bit the bullet and took the plunge. Here is the tail light/pillar light set I bought.
I have to admit that the thing that really sold me on the set was a video of the animated functions.
So, for your viewing pleasure here is a set of three videos.
First, the unboxing and bench testing.
Next, upgrading the license plate lights to LEDs and installing the pillar lights.
Finally, installing the tail lights.
Note that the tail light installation did not go smoothly. I needed to do some surgery on the light's back housing and rewire both lights to get them to work with my car's existing wiring harness. It was not the plug and play swap out which I expected.
Old Apr 21, 2020 | 12:37 PM
  #103
DannyJ7's Avatar
Those tails look awesome Todd. Great work!
Old Apr 26, 2020 | 01:20 PM
  #104
ToddF's Avatar
3D printed and installed a replacement for my center console latch that broke. Thanks bornemanm for designing the part and posting the link.
Old Apr 27, 2020 | 01:04 PM
  #105
ROTTBOY's Avatar
Rare color, unique looks, sharing installs w/ videos - keep updating the good work! 👌
Old May 8, 2020 | 02:45 PM
  #106
ToddF's Avatar
These next two videos aren't strictly about the Fit, but go towards what I use my car for. With all the shutdowns from the coronavirus, I've not been able to pursue my normal hobbies, so have fallen back on hobbies from years gone by. I used to do tons of kayak fishing, carrying my kayaks on the roof racks of my previous cars. Because of this I know that this can be hard on the paint. No matter how careful you are, eventually you are going to scratch up your car getting the kayak on or off. I wasn't going to take a chance of this happening with a car I care about, so I invested in a trailer for large item hauling. Despite having it for more than a year, I really hadn't used it much until recently. The thing that really made the difference was purchasing a second hand Yakima Skybox cargo carrier and installing it on the trailer. Here's how I did that installation.
One issue with used equipment is that it almost never is in perfect condition. Being a handy guy, I'm willing to do a little repair work to save some cash off the purchase price. In this case, the Skybox lid supports needed replacing. Rather than paying $730 for a new one, I paid $150 for the box and $20 for replacement lid supports. Here is how I upgraded the lid supports.
Old May 8, 2020 | 02:53 PM
  #107
ToddF's Avatar
Though the Skybox is great for all the kayaking gear I want to haul, I didn't want my nice rods and reels rattling around in the cargo carrier with everything else. And I didn't like the various other solutions people have come up with for carrier rods on their trailers. I've always liked the security of carrying them in my car. But, if I'm going to do that, the rod holders need to be nice, not some cheap looking hack. Here are the rod holders I made for the Fit, from quarter-sawn oak.
If you really want to see the details of how they were made, there are videos on my channel showing every step of the process. I won't bother linking to them in this thread.
Old May 17, 2024 | 09:36 PM
  #108
ToddF's Avatar
I haven't made any large changes to my car in a while, but it needs a bit of maintenance. I'm tired of swapping in new LED map light bulbs when they die, so I got some
LED panels from Amazon LED panels from Amazon
. I made some 3D printed parts to hold these panels up in the fixture. The two sides are different, so there is a LH and a RH part. If you want to use my parts, you can https://www.printables.com/model/883271-honda-fit-overhead-led-panel-holder and print your own.
Old May 17, 2024 | 09:47 PM
  #109
ToddF's Avatar
My 4 channel amp that was driving the door speakers died about a year ago and I finally got around to replacing it. Unfortunately, the original is discontinued, so I couldn't do a direct replacement. I had to swap in an
amp from a different manufacturer amp from a different manufacturer
. (Kenwood KAC-M1814 4-Channel Compact Bridgeable Marine/Motorsports 400W Max Power Digital Amplifier) It was a little larger than the NVX amp, but I managed to wedge it into the same space in the dashboard.
Old Nov 11, 2025 | 05:16 PM
  #110
ToddF's Avatar
Sad news. After having the Triple Helix mobile for 9 years, I got rear ended. Repairs were too expensive, so the insurance company totaled the car.
Insurance doesn't give credit for all the aftermarket improvements I made. I swapped out my wheels (with new tires 3 weeks old). Also pulled out the subwoofer, sub amp, and door speaker amp. Left the door speakers, interior lighting, and trailer hitch as too much trouble to remove and not enough resale value to be worth the hassle. Didn't want to take a chance on a used car, and 2020 fits are going for what they originally sold for new. So I moved to a Kia Soul.
Old Nov 12, 2025 | 02:59 AM
  #111
Action Jackson's Avatar
Sorry to see this. Hope the Soul works out for you.
Old Dec 1, 2025 | 07:20 PM
  #112
2Rismo2's Avatar
Dang that's nearly exactly where my Fit got hit in September and was also totaled:
Crash pictures
Insurance gave me $10200 for my 2015. Not bad considering it was 10 years old and I paid 20k when it was new.
Were you in the vehicle when it was hit? Did you get any money for yourself?
Press Fit
Jul 28, 2023 12:21 AM
over40pirate
Apr 25, 2013 12:25 PM
White_GE8
Jul 14, 2011 08:03 PM
mgrant
Apr 29, 2009 08:54 PM
lxwhite
Nov 5, 2008 08:18 AM
