TougeMonster_GK5's Build Thread
I plan on getting those this Saturday! going to attempt to install my H&R 10mm spacers so this will enable me to get into the wheel well.
A fellow member USDS, has this explained in his build thread with pics!
Are you swapping in a new seat soon?
I just got my 65mm to 56.1mm center hub rings and plan to throw those on as well this weekend. I still cant get off of my mind the gap that exists between the center bore of my TEs to the wheel hubs.. Even after the alignment, I am not sure if I am imagining that the car vibrates at Highway speeds due to the absence of the centric hub rings, but I want those on immediately for peace of mind..mind you I had centric hub rings on my last wheel setup, no vibrations then.
Check out the links below:
https://www.fitfreak.net/forums/2nd-...ll-begins.html
https://www.fitfreak.net/forums/3rd-...ml#post1383703
Glad it worked out!
Thanks for checking out the thread! I installed the RS wing myself, direct bolt on, just had to tuck the factory window wash sprayer away and plug it up since it cant be used with the wing.
thx 4 showing me those beautiful rolled fender pix! as predicted, the fit barely has much "lip" to roll in stock form. but additional clearance is always welcome!
wait..so if u get the RS wing, u have to lose your rear washer spray?!
The REP RS Wing I purchased on Aliexpress doesn't have an opening in order for me to use the stock rear washer spray. I could have drilled/cut-out an area for it, but didn't want to take a chance on it, I waited over a month for it to get here and just wanted it on.
The other REPS available (via Ebay, Amazon) require professional body work to get bolted on. I would have gone real JDM, but that requires the entire JDM Hatch...
You are most welcome! If you noticed in the pics, the guy who rolled my fenders also cuts portions of the inner well plastic shroud.
https://www.aliexpress.com/snapshot/...Id=32801475239
Do you have another link for the wing by chance? All the ones on AliExpress look the same, and same as the ones on eBay. Really interested if it just bolts on! Although I do use my rear wiper spray occasionally.
Really wish the aftermarket would get USDM friendly already!
