Z062FIT's 2017 GK HPDE Demon Build Thread
Old Aug 8, 2018 | 03:21 PM
Z062FIT's Avatar
*** UPDATES *** Z062FIT's 2017 Fit Time Attack Demon Build Thread
*** If you stumble onto this page, I try to keep the mod list as fresh as possible... ***
OK, so quick update, I have owned my Fit for 4 years this month. It went from my daily driver to my HPDE car. I have a fully built L15B1 motor, and was going for the N/A world record. Unfortunately, I switched goals and am fully pushing to Global Time Attack. At this point, I am preparing to boost the engine, finish the roll cage, install all safety equipment, upgrade brakes, suspension, tires, and build carbon fiber aero. Then shakedown runs and tune. I have a Link ECU which supports direct injection and boost. I have a few folks who are helping me build the car, namely Hotboii Factory in San Antonio owned by Josh Brown. I am hoping to be in a Grid Life event in August so we will see.
Goal is 505 Crank Horsepower @ 2,000 lbs, same as my Z06, just half a ton lighter!
Mods so far:
ENGINE:
1.6L L15B1 block built and assembled by Golden Eagle. Align bore honed, sleeved, custom Traum 12.5:1 pistons, Maxpeeding rods, ARP hardware throughout
PPR Motorsport CNC ported head with 1mm oversize intake, 2mm oversize exhaust, titanium hats and retainers, PPR valve springs, titanium coating on valves.
Bisimoto Stage 3 Grind by Web Cam
RZCrew Intake manifold
Walbro 525 E85 pump
Link G4 GDI ECU
Hardwire PDM 15
PRL Custom High pressure fuel pump
Aftermarket L15B1 Injectors
Garrett G25 660 Turbo with V-band in and out
Custom external wastegate
Custom top to bottom intercooler
Custom intercooler piping
Link Flex Fuel Sensor
RZCrew Sportsman header
Custom SS Downpipe
Custom titanium B-pipe and exhaust
Custom wiring harness
Li-ion anti-gravity Battery relocated
Fuel Cell
BRAKES:
Wilwood 6 piston front calipers 12.19" rotor
Wilwood 4 piston rear calipers 10.9" rotor
Antilock Brake Removal
Custom brake lines master cylinder to proportioning valve
Goodridge stainless steel brake lines (all 4)
Motul RBF 660 racing brake fluid
Acuity Throttle Relocation Bracket
SUSPENSION:
Progress Rear Sway Bar
Front sway bar eliminated
Godspeed two-way adjustable coilovers - custom built
Tailored Chassis Solutions Caster Camber Plates
ASR tubed A-arms
Megan Roll Control Actuators on front control arms
Caster camber shims in rear
Powerflex street bushings front (did not have race option) and race bushings rear
Entire Chassis stitch welded, seam sealer removed, noise reduction removed
TRANSMISSION:
mFactory 1.5-way Limited Slip Differential
Clutchmasters lightweight flywheel
Clutchmasters stage 4 clutch
** Looking for GK5 gear upgrades any help appreciated H.Car out of Thailand?
Acuity Shifter Bushings
BG Synchromesh Transmission Fluid
Buddy Club CR-Z short throw shifter
Megan 12oz tall shift knob
SS Clutch line
AERO:
Custom Carbon Fiber Front Splitter
Custom Carbon Fiber Rear Diffuser
Custom Carbon Fiber Rear Wing
Custom Carbon Fiber Roof
Aluminum lower engine cover
Drilled out the fake vent panels on the rear bumper and around the left front fog light
Custom fender flares
ERGONOMICS:
NRG Race Seats
NRG Race Harnesses
NRG Carbon Fiber Steering Wheel
NRG Steering Wheel Quick Release
Integrated cameras on roll cage
SAFETY:
Hotboii factory Custom Roll Cage
Fire Supression System
HANS device (must have for racing with Porsche club starting in January '19).
Mods I still want to do:
Underdrive pulley
camera bar
Real areo front splitter
Real aero rear spoiler
Gut the interior?
Roll cage for sure!
Brake cooling ducting
Old Mods
Acuity titanium shift boot collar
Ported my intake manifold at home
Ported my throttle body at home
Honda S2K throttle body
Custom 3" intake piping with air filter relocated to left fog light
Spoon or custom B-pipe
Weapon-R Cold Ram Air Intake thru Fog light
HPS Short Ram intake
HKS Silent Power over the axle exhaust
RV6 catted downpipe
BC Racing DS Series Coilovers 10K Front/8K Rears
Koni STRT shocks and struts
Tein performance springs
SPC camber bolts in the front for negative camber, 1 on each side
Konig 15 x 7.5" Hypergrams
Maxxis VR-1 205/50/R15s (my race tires and rims)
Power Stop racing rotors and pads
Porterfield R4S brake shoes
Schroth 4 pt racing harness
U80A urethane for stiff mounts
Rear fenders rolled and internal noise reducing felt flaps trimmed
OE Honda Mud flaps (4 ea)
Limo tint all the way around, ceramic tint on windshield
Rockford Fosgate amp and 12" sub
Just.Cant.Stop...
Cheers! -d'Art
Old Aug 8, 2018 | 03:23 PM
evilchargerfan's Avatar
FIRST!
finally ........ looking forward to some awesome progress!
btw ... PICS! lets see some PICS of that thing!
Old Aug 22, 2018 | 02:35 PM
Z062FIT's Avatar
Rims on with new suspension
installed the mud flaps and rolled the rear fenders
Old Aug 22, 2018 | 10:33 PM
Z062FIT's Avatar
The bulge from fender roll
Old Aug 22, 2018 | 11:03 PM
Z062FIT's Avatar
OG, no mods
As I bought her, not even tinted windows
Old Aug 22, 2018 | 11:29 PM
drmwgn's Avatar
Bronze wheels on white paint look great! Keep it up man, lookin good !
Old Aug 30, 2018 | 11:16 PM
eulogy's Avatar
looks good man. white cars look so crispy n nice. mod list lookin good too...i like the bronze wheels and the oe mudguard look!
ps...rear fenders dont look too bad!
Old Sep 18, 2018 | 03:39 PM
Z062FIT's Avatar
Getting ready for track weekend coming up
My second time to Spring Mountain. Requested an instructor again, at least for day 1. Then I drop off 180 lbs of ballast and watch out! I got the ktuner v2 in the mail and I'm wondering if I should do a baseline run with the stock tune. I've done a lot of mods since May, and plan on a lot more. Maybe I should just go straight to the canned tune???
Old Nov 12, 2019 | 02:56 PM
USDM's Avatar
This is due for some updates! :P
Old Nov 12, 2019 | 10:22 PM
Z062FIT's Avatar
No doubt!
Here is the track beast with my shitty wrap! Good times! More fits below!!!
Old Jun 28, 2020 | 11:47 PM
Myxalplyx's Avatar
Great looking car! Yes, for updates.
Old Jun 29, 2020 | 10:15 PM
Z062FIT's Avatar
Look for my engine tear down thread
I've moved to Southern Maryland so we're practically neighbors, well v. Las Vegas where I was...
Old Sep 14, 2021 | 10:48 PM
Done Deal DR's Avatar
Nice build! What are your thoughts on the BC DS coilovers?
Old Dec 9, 2021 | 12:43 PM
Z062FIT's Avatar
Bc ds
They're pretty good. A friend of mine is trying to get me to switch to godspeed. We'll see...
jhn
3rd Generation GK Specific Suspension & Brakes Sub-Forum
20
Dec 26, 2018 07:14 PM
Vtecfreeak
Oct 14, 2014 07:39 PM
chinkyy
Hawaii Community
Oct 17, 2009 01:44 PM
Jazz GD3
Jul 11, 2009 03:07 PM
Illmatic07
20
Jun 12, 2009 04:16 PM
