air pressure - 2017 Honda Fit EX - 16" stock wheels with Firestone tires
Old Jul 27, 2019 | 06:56 AM
nboboloo2's Avatar
Hi Folks
I bought a salvage 2017 Honda Fit EX with the stock 16" aluminum rims (with Firestone tires).
Anyone have this vehicle?
If so, what does your tire pressure label say for pressure range? (Mine was lost from the collision repairs.)
I don't want to over-or-under inflate my tires (right now set at 32 lbs and had a tire pressure light just turn ON).
Thanks
Rob
Old Jul 27, 2019 | 07:33 AM
exl500's Avatar
I'm not looking at the car, but I recollect 34 front, 33 rear.
Old Jul 27, 2019 | 05:21 PM
wasserball's Avatar
Read the manual to understand how the Fit TPMS works. If you don't have it, it should be available online for you to download. It takes a while for the system to figure out the tires are properly inflated. A pound difference should not activate the TPMS system unless a tire is low in pressure. Secondly, I don't trust the TPMS. I was running on a flat tire and the TPMS did not trigger.
Old Jul 27, 2019 | 06:24 PM
exl500's Avatar
On my original Firestones I'd get false TPMS readings, especially on long trips. In the 10k miles since I put the Michelins on, none. So TPMS goes both ways.
Old Jul 27, 2019 | 08:14 PM
Fuelish's Avatar
Mine has nothing about tire pressure in the door jamb area, just a VIN and the manufacturing data, must be in the manual... 32 PSI is fine
Old Jul 27, 2019 | 08:39 PM
nboboloo2's Avatar
same here
nothing on my door post (except what you said) -AND- if you look at the online manuals (mine never had the paper manuals), there aren't any exact numbers (but an awful lot of other tire pressure related stuff
thanks
rob
Old Jul 27, 2019 | 09:33 PM
woof's Avatar
This is from the 2018 manual I downloaded for my car. Essentially for the EX the front pressure is 33 PSI and the rear pressure is 32 PSI. I have an LX not an EX but I run 35 PSI all around because I find different front/back numbers to be confusing and 35 is nice and simple and easy for me to remember albeit a slightly harder ride.
Old Jul 31, 2019 | 01:35 AM
Mercyhold's Avatar
A typical reset could potentially solve the problem
Old Aug 10, 2019 | 12:06 PM
nomenclator's Avatar
I fill my LX to 35 psi on all 4, when cold. Of course my stick-type gauge will not read the same every time. It can go out to 34, then on the next check a minute later go out to 35. And I don't know how accurate it is, but I know that I get the same numbers on my OTHER stick (I have one that goes to 50 psi and one that goes to 100 psi. I got very even tire wear on my original Firestones. No difference between inside and outside treads. No difference from point to point on the circumference. No feathering or cupping was noticeable. The TPMS lets me know when the pressure has gone down to 32. Takes about 2 months. Maybe more. They lose air pretty evenly. However I've seen a 2 or 3 psi difference at different temperatures. On the side car that has the sun beating down on it, the tires feel a lot warmer when touched, and the psi can become 2 pounds higher than the other side. I've found that warmth from the sun has more of an effect on temperature than driving at 75 mph on the interstate for 2 hours, in 80 degree F weather!
My new Pirelli P4 Four Seasons Plus lose 3 pounds of pressure a bit faster than than the original Firestones did. After about 2 months instead of 3 months.
Old Aug 11, 2019 | 06:33 AM
nboboloo2's Avatar
Smile thanks
I set them now to 34 front, 33 back.
I bought a digital tire pressure gauge (v.s. the dozen or so old stick gauges I have).
resetting the TPMS is in the one manual ( https://owners.honda.com/vehicles/in...17/Fit/manuals )
thanks everyone
Rob
spaceballs
Nov 15, 2018 09:09 PM
James Butler
Nov 19, 2014 11:16 AM
bigcanoe
Nov 4, 2014 04:19 PM
vwli
36
Jul 31, 2014 04:01 PM
agios11
Aug 24, 2012 11:41 PM
