Snow Tire Pictures
Old Sep 29, 2014 | 09:09 PM
  #41
JN2k108's Avatar
Originally Posted by rodney
i went with the 185/65-15, in the general altmax arctic. at stock height, i think it is the most you can get under there without clearance issues.
it is much taller then the stock 185/55-16 when the tires are next to each other, but the fenderwell clearance only has to deal with half that measurement.
i am still waiting on wheels, but if you want me to get a pic i can.
I'm thinking of going with the 70 profile but I haven't done the calculations yet. But if you could, measure the top of the wheel well to the top of the tire.
Old Sep 29, 2014 | 09:14 PM
  #42
rodney's Avatar
no way are you getting a 185/70-15 to work efficiently. it will be too tall. it is dark, but lemme see if i can get a pic. brb.
and log into aim...
Old Sep 29, 2014 | 09:18 PM
  #43
JN2k108's Avatar
and log into aim...
Lol I just checked tire rack and the 70 profile isn't common so 65 will have to do.
Old Sep 29, 2014 | 09:29 PM
  #44
rodney's Avatar
good, because imho, it wouldn't work anyway.
ground to middle of wheel arch as is in my driveway is 25 5/8".
same angle with unmounted 185/65-15 general (mounted will get slightly taller)
i don't care what the math says, in reality it is a much taller tire.
Old Sep 30, 2014 | 05:36 AM
  #45
JN2k108's Avatar
Oh wow. It fills the wheel gap nicely
Old Sep 30, 2014 | 06:46 AM
  #46
Black3sr's Avatar
I would still recommend looking for a used setup. You can find all sorts of tires and wheels for half the price or less of new.
Old Sep 30, 2014 | 06:53 AM
  #47
rodney's Avatar
something to bear in mind is most snow tires have multiple compounds built into them. blizzaks have softer compound at the initial tread, which hardens as the tire wears. so, even though the tire has meat left on it, it will not perform "as new".
regardless, a worn snow tire is still better then a worn all season tire.
Old Sep 30, 2014 | 07:01 AM
  #48
SilverEX15's Avatar
Right. Years ago, they started using a compound that was called hydrophilic, meaning it liked water, so it provides a better grip in wet conditions.
It's never a good idea to get the most possible mileage out of a tire. It's not like a tube of toothpaste.
Old Oct 1, 2014 | 04:29 PM
  #49
jjcentral's Avatar
Can any one with snow tires shed some insite on how the tpms system is acting without sensors or any configuration needed if you have wheel sensors. Thanks.
Old Oct 1, 2014 | 04:34 PM
  #50
SilverEX15's Avatar
From past experience, if you do not have sensors installed and calibrated, the TPMS light will remain lit. You can have the sensors installed by a tire dealer or Honda. Then they have to be calibrated. Buying and calibrating is a very expensive proposition, especially when you consider how long cars and drivers survived without them.
I drove a car all last winter without sensors - no problem.
Old Oct 1, 2014 | 04:42 PM
  #51
jjcentral's Avatar
Thanks for the reply. I was wondering if tpms data is also equated in the vsc algorithms. That's why I wanted to make sure if any one has any issues in this particular car.
Old Oct 2, 2014 | 02:10 PM
  #52
ashchuckton's Avatar
Glad to see you folks switching to winter tires. Makes a huge difference.
Does anyone know what size the center bore is for a Honda Fit? I know the bolt pattern 4x100 is the same as my MINI & the wheels should fit provided their bore will accommodate the Fit hub. Sure would be nice to use my current snow tire & wheel package.
Old Oct 2, 2014 | 02:13 PM
  #53
stembridge's Avatar
56.1mm
es
Old Oct 2, 2014 | 03:14 PM
  #54
Thank you! Turns out the MINI uses 56.1 too.
Old Oct 2, 2014 | 09:26 PM
  #55
JN2k108's Avatar
I'm sad my winter tires arrived before my fit did lol
Old Oct 2, 2014 | 10:37 PM
  #56
SilverEX15's Avatar
That's funny!
Old Oct 3, 2014 | 04:51 PM
  #57
JN2k108's Avatar
That's funny!
Lol yeah. Dealer just emailed me. They said it will be ready for delivery on Monday
Old Oct 4, 2014 | 11:53 AM
  #58
JN2k108's Avatar
Here are said tires. lol
Old Oct 11, 2014 | 06:46 AM
  #59
JN2k108's Avatar
Check Craigslist or similar places. There are tons of slightly used tires and rims out there.
I have 15" on mine for winter. I like the slightly softer ride as I am on Swifts. Tires are
185/65R15 BFG Winter Slalom
what size center caps are those? I'm looking for some.
Old Oct 11, 2014 | 10:43 AM
  #60
Black3sr's Avatar
They are 2". See this thread how to do them. THey are made by Mr Gasket for late GMs.
https://www.fitfreak.net/forums/gene...er-caps-3.html
