Heads up recall: low beam on Head lights
Old Mar 15, 2011 | 07:14 PM
  #41
seanpatsdad's Avatar
Originally Posted by mxl180
My headlights did go out... 6 months ago
Thanks for the picture.My lights went out last night(low beam).I checked the harness and it looks just like the picture.Going to the dealer next week.thanks again for the picture.
John
Old Mar 18, 2011 | 01:08 AM
  #42
Fit4Trav's Avatar
Had mine done this morning only took them about 1 hour and 30 minutes but they also did my oil change as well.
Old Mar 20, 2011 | 05:46 PM
  #43
princedwi's Avatar
They got me in and out for ~1/2 hr, I performed the work last week, had some cocoa and inspected the floor model CR-Z. Looked clean, but I wasn't a fan of the small rear view windows at all on it. They looked awkwardly at my keyport slide when I said to use the blue node (matched my VBP lol) xD
They claimed my PIAA Super Silicone wipers were worn out and that they wanted to replace it for ~$57 + tax. I said no thanks..what crooks they are.
Old Mar 24, 2011 | 10:37 AM
  #44
mikelowell915's Avatar
Recall Problem?
Had the recall done 2 weeks ago and at 430am my low beams didnt work seems both filiments for the low beam burned out at the same time, the dealer told me that it is a coincidence and i had to purchas new bulbs, doesn't seem right to me i tested all the circuits and theres no significant voltage drops, shorts, or open circuits that i can find, has anyone else had this issue? or is it really just a coincidence?
Old Mar 24, 2011 | 08:20 PM
  #45
viperjh16's Avatar
And wen I had it done a week later my altenater blew dealer said it's not our problem 700.00 in hole found out honda cut a wire causing a lOad on it all the time killing it got it fix now I'm getting rid of the car and going ford bc honda fuck this car 3X on recalls And I had to pay for it each time
Old Mar 24, 2011 | 09:35 PM
  #46
KyleB's Avatar
I still haven't taken the car in for the window switch recall or this one. I am a bit hesitant because A) I haven't had any issues and B) I don't like the idea of 'dealer' techs taking the car apart to fix a problem that I don't have. I worked alongside a former dealer tech for a few years and I was shocked at the 'bang it in, bang it out' mentality that dealer techs seemed to be engrained with.
Old Mar 25, 2011 | 12:32 AM
  #47
RichXKU's Avatar
Has anyone with the "independent fog light" mod had this recall done?
Old Mar 25, 2011 | 08:07 AM
  #48
polaski's Avatar
Ditto on Rich's question...
My argument to the dealer is going to be that I wanted to take the load of the fog relay off the switch to prevent this after seeing the harness failures on this forum.
That is half the reason I did it, Ford had a big ol' recall in the 90's on the Escort for this exact same thing because of the foglamp load overloading the lowbeam harness that wasn't designed for it and I didn't want a repeat of history.
That warranty is up in 3 months anyways so no biggie if they get all upset. Shouldn't affect their ability to perform the recall (they splice a bigger wire onto a different wire than we tap into for the indy fogs).
Old Apr 4, 2011 | 09:46 AM
  #49
Willard's Avatar
Originally Posted by Willard
"4 to 5 hours" to replace the switch?
I had the recall done this past Thursday. They called after ~1.5 hours and said it was ready to pick up.
It was raining when I got there (and I was rushed during lunch time) so I jumped in and headed back to work. After I parked at work I checked the steering column cover and sure enough the rear 2 tabs (on the bottom section of the cover) were broken. The tech. must have unsnapped the front two (closer to the wheel) and then hinged it upward.
I called the dealer back and let them know of the issue and he said to come back and they would "look at it".
After some time discussing things in the service bay (with the service writer and shop foreman) they went to the parts department to check to see if they had one in inventory. Come to find out they are back order (national?) and it would be a few days/weeks before it arrives.
77360-SAA-G02ZD COVER ASSY., COLUMN (LOWER) *NH674L* (US MONO GRAY METALLIC)
Old Jan 1, 2015 | 03:14 PM
  #50
Mapone's Avatar
Today it happened to me. During a long time driving I felt something like burn plastic. I turned the lights OFF and from that moment I can't turn the headlights ON. Only parking light and high beam are working...
I disconnected the connector under steering column cover and found this.
Size:  78.7 KB Now I see I'm not only one with this issue...
Oniongod
Nov 25, 2015 02:19 PM
raynagin
Sep 13, 2014 09:21 AM
hogwylde
Jul 2, 2013 12:48 PM
nmfit2008
Jan 13, 2011 05:40 PM
senador
Feb 28, 2008 10:13 PM
