Sponsored by:
Sponsored by: CARiD
Dashcam fusebox connecting question
Old Jul 9, 2019 | 08:33 PM
DisappointTheFuture's Avatar
Question Dashcam fusebox connecting question
I just bought a Rexing V1P Gen3 front and rear dashcam. I have a 2019 EX and I was wondering if it was possible or smart to connect the camera directly to the fuse box to have the camera always on.
Any advice would be greatly appreciated. I'm pretty handy with repairs but I am unfamiliar with electrical stuff.
Old Jul 9, 2019 | 09:16 PM
2Rismo2's Avatar
Wouldn't that drain the battery after a while if your intention that it would always be on?
Old Jul 9, 2019 | 10:07 PM
woof's Avatar
He's right. Dashcams have a high current draw. As long as you're running your car every day which will recharge the car battery you might be OK but if you let your car sit for a day or two because you're not using it then you might not be able to turn it over. If your dashcam has a motion detector so that it's only on when movement is detected then that would be much better than just always on.
Old Jul 10, 2019 | 10:58 AM
Action Jackson's Avatar
Get a dashcam battery pack. Made a huge difference for me. https://www.blackboxmycar.ca/collections/battery-packs
Old Jul 11, 2019 | 03:30 AM
That is my fear, especially since the fit battery is smaller...
Old Jul 11, 2019 | 03:32 AM
Thank you for the info. I went ahead and just used the standard power adapter it came with instead of trying to wire it into the fuse box. I will check out the batteries for the future though.
Old Jul 11, 2019 | 07:36 AM
2Rismo2's Avatar
I had actually looked at using a jump starter pack I had. Have that charging while driving, then plug in the dash cam into one of its USB ports. I forget how man MA it has but should run for a while at least.
Old Jul 11, 2019 | 11:31 AM
I've read about people trying that. I can't remember what the problem was in this method, otherwise I'd have pursued it.
Old Jul 11, 2019 | 11:33 AM
I've drained the tiny battery with the dashcam. Even if I set the power drain to stop at higher voltages, the stock 151R battery was a joke and not up to the task.
QuiGonQuinn
Aug 31, 2018 07:52 AM
RavenManiac
Sep 22, 2017 11:13 PM
kellyjoy
Mar 19, 2015 07:10 AM
Fat_man
Sep 4, 2014 11:35 AM
Fitcious
27
Jul 18, 2010 04:34 PM
