Towing MT 2nd gen Fit behind U-Haul 2 up?
Old Aug 29, 2019 | 01:15 PM
xcmove's Avatar
Hi all,
About to move west from Colorado over the mountains and I currently have a 10' truck with a tow dolly reserved for me. I have a 2013 manual transmission Fit that I just took in for an oil/filter and transmission fluid change, so we're good to go there (tread on the tires is fine, brakes are down to 3/32 but I'm planning to take care of that once I land).
I'm currently just planning to tow it with the two front wheels off the ground/on the dolly and the two rear wheels on the road. I'm a little worried because of the Fit's relatively low clearance, so just wanted to check and make sure others had done this before. I'm being overly cautious, right? This should be fine? (Considered towing a trailer behind the Fit, but decided against it after reading your advice on this forum, so thank you!)
Old Aug 29, 2019 | 02:31 PM
fujisawa's Avatar
You will not have any transmission issues. Ground clearance, I cannot say.
Old Aug 29, 2019 | 09:19 PM
GodFather's Avatar
You have the manual transmission. Why not just tow with all four wheels on the ground?
IfChris_ThenFit
Apr 22, 2025 07:07 AM
bigbacon
Feb 1, 2020 07:03 PM
4077
Jun 4, 2018 07:43 PM
Sassy42
Sep 25, 2017 11:47 PM
GENISIS
Mar 20, 2009 04:34 AM
