08 Fit - key won't turn in ignition
My friend has a 2008 Fit that won't start. Apparently the ignition switch - or an interlock somewhere - is the issue, because it's impossible to turn the key even when applying the brake. As a result (I think) it's impossible to shift the car out of park, so we can't push it to a more convenient spot.
Is there a way to overcome the ignition lock so the key will turn? Or a way to overcome the transmission interlock so the car can be shifted into neutral?
Thanks
Edit: my friend reports that he can now turn the key in the ignition, but still can't get the transmission out of park.
Thanks
HighMileage07
Jul 20, 2020 10:16 PM
