Replacing clutch on Honda Fit 2007 sport
Old Nov 21, 2022 | 10:02 AM
Andreas's Avatar
Hi, my clutch started slipping. On highway in higher gear in 5th gear especially. I ordered after price competing several options Brand Exedy OEM (not organic which is more $$):
https://www.exedyusa.com/products/HCK1006
Should i stay with Exedy (still could return) or not?
What else to change while changing clutch? Transmission rubber mounts or even engine mounts ????
Old Dec 1, 2022 | 07:00 AM
newcarscent's Avatar
Exedy OEM replacement is perfectly fine.
Change the throw out and pilot bearings while you're in there, and it would also be a good time to inspect your rubber mounts and clutch hydraulics.
If you're looking for some "while you're in there" mods, the shift cable bushings, shift select spring, and clutch delay valve delete are great mods that add a lot to the driving experience.
Old Dec 26, 2022 | 10:51 AM
mifesto's Avatar
i wouldnt trust any exedy bearings it comes with. there's two bearings in there, one throwout and one in flywheel, go OEM only. inspect flywheel and replace rear main seal.
Old Dec 27, 2022 | 07:20 AM
mobby_6kl's Avatar
Isn't Exedy the OEM for many Japanese manufacturers anyway? I used a LuK kit because they're supposedly pretty good and it's an 18 year old econobox so who cares
Are you going to DIY it? I did a clutch (+ gearbox bearing) replacement here in this thread. It's not a a full guide (you can find some videos on youtube) but there are a few shortcuts you might find helpful.
https://www.fitfreak.net/forums/1st-...ml#post1458641
Old Dec 27, 2022 | 04:07 PM
mifesto's Avatar
from feedback from various honda forums, everyone warns against exede bearings which doesnt compare to oem. also i wouldnt say exede = good simply because they are OEM supplier. Exede makes cheap clutch all the way to fancy triple disk clutches being able to hold 700-800lb torque etc.
Old Jan 3, 2023 | 03:41 PM
anr7776's Avatar
I replaced my throw out bearing with a Honda OEM based off advice from this forum and other sources who mentioned the Exedy bearing wearing out early. It's been flawless since and I've put about 15K on it. On a side note I used the an Exedy stage 1 and it's been the only mod I've done to my Fit and I'll never go back to OEM. It really wakes up the 1.5 by letting it punch into the power a little harder then the stock clutch will. I only regret not having the money to put a limited slip in at the same time.
Old Jan 4, 2023 | 04:49 AM
USDM's Avatar
Clutch disc is fine—stick to OEM for the bearings.
TOORAPH
Sep 12, 2015 01:36 AM
Niki4os
Feb 1, 2015 07:49 PM
radfit
May 11, 2012 11:54 PM
trashercan
Jul 9, 2010 01:12 AM
byebyepanda
Sep 1, 2007 12:21 AM
