valve tick
Old Dec 30, 2006 | 07:53 PM
wademunkey's Avatar
valve tick
I had put my car in teh driveway idling for a couple of minutes, when i returned the car was ticking very lightly. My car has jsut over 1000 miles on it a sport auto. And before you ask, yes there was someone in the car. I also own a 1991 mazda miata. If my mazda was making this noise I would be scared. Is this a characteristic of this motor, or of honda's? This is my first honda. Thanks for the opinions.
Andrew
Old Dec 30, 2006 | 07:54 PM
Tomh's Avatar
Senior Member
mine has a little over 6k miles and doesn't tick.
Old Dec 31, 2006 | 01:26 AM
Poptarts's Avatar
its probably not a valve tick. the injectors are so small for these motors they make a ticking sound when firing. but like claymore said, if you can hear while driving, have it checked out.
Old Dec 31, 2006 | 01:40 AM
Paulo107's Avatar
inject me with some fuel baby>>>mine does that and its normal and i have driven the engine hard since 6 miles on odometer
Old Dec 31, 2006 | 11:53 AM
wademunkey's Avatar
alright, so it is just at idle, not even noticable unless you listen for it. I am used to my miata that drinks oil like there is an abundant supply, and tells me when to add:-D. Good to know it is normal. Thanks
Andrew
Old Jan 4, 2007 | 08:53 PM
sparkedfire's Avatar
Just over 12k miles and mine ticks. Don't have any other fits to compare it to, but I know it's louder than when I first got her. Runs fine though.
Old Jan 4, 2007 | 09:22 PM
GoFits's Avatar
18k and yeah it kinda sounds like a sewing machine....but it's a 1.5ltr so it's not gonna beefy.
Old Jan 4, 2007 | 10:03 PM
milano sol's Avatar
i too have had teh valve train/injectors tick....quite when warming up.....at idle and running temp its noticeable but car runs great (pulls hard when asked too and gets 34mpg city when im tame with it.....) so im not worried about it.
Old Jan 5, 2007 | 11:11 AM
OK_LA's Avatar
Guys, My Fit has the same tickling noice while in idle. I've just had my Fit checked on this issue today from the dealer. They said it is the valve making that noice, and it is normal. But I will keep an eye on it.
Old Jan 5, 2007 | 11:25 AM
milano sol's Avatar
yeah most VTEC motors have some valve train noise.....my EG Hatch w/ B16A makes tons of noise but all is normal and good so i would expect the same from the fit....of course its not as loud as the EG heheh
Old Jul 30, 2010 | 08:33 AM
HOLY FIT!!'s Avatar
i know this is a way dead thread, but worth opening back up, hows everyones motors sounding now? i did a valve adjustment because of the ticking, valves were out of spec, but it still ticks like it did before. i used an automotive stethoscope and took a listen on the valve cover, very slight ticking....then i put it on the injectors...loud ticking. and my motor now has 35k
Old Aug 2, 2010 | 05:05 PM
S4guy2000's Avatar
I switched our Fit Sport to Pennzoil Ultra oil and it runs like a freaking Singer sewing machine now. It ticked a bit before, but now it is really, really smooth and quiet. It starts easier, is quieter, and actually revs much better. Really highly recommended if you want to quiet the car down and run a really good synthetic. Wal Mart just dropped the price down to $25 for the 5 qt. jugs too. I would still use the Honda OEM oil filters though.
Old Aug 2, 2010 | 05:16 PM
fitchet's Avatar
I own a relatively new 2010 Fit Sport, it now has a little over 4000 miles on it. I'd say when I first got it and for the first 2000, 3000 miles I was very concerned about valve tick and engine noise at idle.
It seemed loud to me, louder than my previous vehicle which was a 1993 Honda Accord.
Now, I can't honestly say that part of it isn't just my own adjustment as driver/owner BUT I would say that since about 3000 miles onward, it seems to me the car engine has broke in, and is idling smoother and ticking less.
I don't run premium gas, but I do purchase from "Top Tier" stations.
Infact, I did take mine to the dealership and mentioned the valve tick, not because I had hopes they could fix it, but I did want it noted IF I had a problem down the line. The dealership (of course) told me it was "normal". I drove with the attitude that if it got worse? It was a problem. My observation, has been that as the engine has broke in, the tick has decreased. So you might want to have it officially documented and checked, but then just relax and see how it goes for the next few months.
It drove me nuts at first, but now whether IT has gotten significantly quieter or I've adjusted to the sound or a combination of the two, it does seem to me much better at 4000+ miles than it did when I first got it.
Old Aug 2, 2010 | 08:04 PM
FitFlowjoe's Avatar
My '07 has about 50k on it now and the engine makes that ticks, the only time it gets quieter is when the oil is fresh.. and I use AMSOil 100% Syn. 0W-20.
But my motor has always made that noise. It now has an intake/header/cat-back now.. and still makes the noise, maybe even louder :/... Still getting 28~34mpg everyday.
Old Aug 3, 2010 | 07:15 AM
HOLY FIT!!'s Avatar
i did a valve adjustment on mine, all the valves were out of spec, the ticking was the same as before....and now it seems like its even a bit louder...hmmm
Old Mar 27, 2011 | 09:02 PM
patm95's Avatar
I recently had the recall done on my '09 fit. Before when I got my car new, you couldn't hear it run sometimes. Now I can hear the ticking from inside the car! I am taking it back in this week!
Old Mar 29, 2011 | 10:52 AM
Uncle Gary's Avatar
Same thing happened to mine. I took it back and had the service manager listen. He decided it was out of spec, so I took it back and they adjusted the valves again. Everything's back to normal now.
Old Mar 29, 2011 | 09:28 PM
patm95's Avatar
Got mine worked on today. Luckily, the service man immediately recognized the problem and got it fixed.
allTRACway
Mar 11, 2016 04:06 PM
g fit
May 12, 2014 07:06 PM
ricohman
May 22, 2011 09:34 PM
qbmurderer13
Feb 17, 2010 10:53 PM
abell
Jun 19, 2006 08:32 AM
