is this oil Or atf leak marking?
Old Jun 14, 2023 | 04:49 PM
EVO's Avatar
EVO
Question is this oil Or atf leak marking?
Hello all,
Does anyone know what may be the cause of this nasty oil marking or where exactly it's coming from?
attached photos,
(Next to driver side axel)
many thanks in advance,
Old Jun 15, 2023 | 12:26 AM
Pyts's Avatar
Sorry there, I have a manual trans, is that right where the engine and transmission meet? That dirty nub in the second picture looks kinda like a rubber cover for access to flex plate bolts.
​​​​​If so, you could pull that cover out and check for fluid inside.
If you could get another shot showing proximity to another component, like cv shaft, that'd be sweet.
Old Jun 16, 2023 | 08:16 AM
EVO's Avatar
EVO
this is not mine, I took a screenshot from Youtube showing a guy that he has a similar but worse leakage than mine,
after some research, I assumed it is old atf since the car once was overfilled by 1 qt with atf (changed it with the right amount~ 3 qts). The marking is somewhat dry, I shouldn't worry, right?
Old Jun 16, 2023 | 11:26 AM
Frenzal's Avatar
Clean it and watch if it comes back.
Old Jun 17, 2023 | 01:50 PM
Odie's Avatar
I use window cleaner for this because it cuts through oil and grease with ease . Update us on your finding . Pictures would be a bonus and the best of luck .
Old Jun 29, 2023 | 04:51 AM
EVO's Avatar
EVO
Thank guys,
I cleaned it with Windex and it's dry ever since
Old Jun 29, 2023 | 03:08 PM
Odie's Avatar
. Hope it remains that way . Still may want to check monthly or every few . Keep us informed if any change .
Press Fit
Mar 18, 2024 02:05 PM
Ogrelode
Feb 24, 2019 09:14 PM
cleanest135i
May 16, 2017 07:05 PM
Scotty2h
Aug 27, 2015 06:19 PM
Vince_TB
Apr 25, 2014 11:58 AM
