Daylight Running Light ("DRL")
Old Mar 19, 2007 | 12:18 AM
Sera's Avatar
Hi, if you note on your Owner's Manual and then in the Quick Start Guide; the Manual says that if the "DRL" indicator comes on when the ignition is On(II) and the parking brake is RELEASED, there's a problem. But, the Guide says that if the indicator comes on when the ignition is On(II), the headlights are off and the parking brake is SET, there's a problem. So which is it? When the light comes on when the parking brake is released, or when it is set? Anybody have a clue? Thank you very much for your time.
Old Mar 19, 2007 | 12:22 AM
Fit of RAGE's Avatar
there's a problem if the light is on and the park brake is NOT pulled up. Most likely, yoru brake fluid is low if this happens
honestrands
Oct 15, 2021 10:53 AM
daves007
Apr 26, 2015 07:11 AM
chinkyy
Mar 4, 2013 10:37 AM
Wolfvision
Apr 5, 2011 12:48 PM
Chrysi
Mar 21, 2011 03:57 PM
