ATF Fluid Change
Old May 25, 2007 | 04:23 PM
Wiggles's Avatar
ATF Fluid Change
Is there a way to drain the torque converter on the U.S. model Fit when changing the fluid?
How about an ATF cooler return line that can be disconnected to allow flushing?
Jim
Old May 25, 2007 | 04:54 PM
H8TON's Avatar
Unfortunatly no,the only real way to get 100% of the fluid out is to due a trans. flush! My suggestion if you keep up with your service you can due a drain and fill and have no issues.
Old May 27, 2007 | 08:43 PM
manxman's Avatar
Jim
I share your concern- would like to completely drain my auto trans. and switch to synthetic Amsoil ATF (Honda approved). But about half the ATF in the trans. is in the converter. I believe that a transmission service shop can completely drain the trans., and I will try this approach in the near future. If I am successful, will post results on the forum. I might try a few phone inquiries right after this holiday weekend.
1lowufo
May 26, 2019 12:43 PM
JerryHughes
Apr 10, 2019 11:33 AM
domromer
Feb 19, 2019 06:37 PM
kaede1337
Jul 31, 2016 05:22 PM
Santiad
Sep 28, 2010 08:54 AM
