using high beam----no fog light ??
Old Jul 27, 2007 | 05:11 AM
FELIXY69's Avatar
i just installed hid and then realise , with it being at high beam, the fog light goes off.
did i do something wrong or is this how it's suppost to be?
also does anyone know how to wire the DRL to my fog lamps or he position lights ?
my drl didn't work with the new hid
thanks
Old Jul 27, 2007 | 08:57 AM
Fit of RAGE's Avatar
It's illegal to have your Highbeams and foglights on at the same time. It's normal that the foglights will automatically turn off. As for teh foglights at drl, there's a DIY for it: Independent Fog Light PROBLEM SOLVED
gummyrabbit's Avatar
That's the way it is from the factory. When you turn on the high beams, the fog lamps turn off.
Old Jul 27, 2007 | 08:58 AM
It depends on what country you're from...
Old Jul 27, 2007 | 09:18 AM
Spule 4's Avatar
Even if not illegal, having both fog and high beam lights on would be counterproductive, now wouldn't it?
Old Jul 27, 2007 | 09:28 AM
DagerOne's Avatar
Exactly, which is why it's hard-wired that way in cars from the factory. It's usually a simple fix (jumping a relay, e.g.) to take that limitation out, as folks here have determined and described in the above thread. But people who want to show off their lighting for one reason or another usually want to bypass it.
Old Jul 27, 2007 | 12:30 PM
FELIXY69's Avatar
oh its ok then i'll just leave it alone.
i was just wondering if i screwed up some where ?
Spule 4's Avatar
I guess I am one of the few that added fogs for their intended purpose of assisting in foul weather.
Back in the day, I have used large wattage DRIVING lights (anyone else remmeber those) on many cars when driving in rural countryside. These are bright and had a beam pattern that shone way down back roads.
http://www.rallylights.com/hella/hel...ng_Pattern.jpg
Versus fog:
http://www.rallylights.com/hella/hel...og_Pattern.jpg
I still have one set (SEV-Marchal) that are probably older than most of the posters on this forum!
NotBlake
Oct 18, 2014 04:47 PM
alanchan
18
Sep 17, 2014 10:05 AM
FITMugen
Mar 1, 2014 10:29 PM
bobos105
Apr 30, 2010 04:24 AM
jthai
Jan 15, 2007 12:41 AM
