Black Fog Light Covers
Old Jan 9, 2008 | 01:39 PM
runbikerun's Avatar
Talking Black Fog Light Covers
Hey, I want to cover the surrounds of my fog lights with something black or carbon instead of the stock silver paint. Any ideas?
I don't know why I have to do this but I am on a mission.
Should I just pull them out and paint them? I checked around to buy the oem black lights but you have to buy the whole kit. IF there was some kind of cover that attaches somehow that would be really cool.
Old Jan 9, 2008 | 01:59 PM
ImPuLsIvE.ca's Avatar
Take them off, paint them black and get them professionally clear coated.
That or get them wrapped in CF if that's what you're looking for.
Old Jan 9, 2008 | 02:40 PM
smatts's Avatar
Honda Fit Forums Moderator
I took them off, removed the actual light housing, then sanded them down, hit it with about 3 coats of flat black, then about 3 coats of clear coat... they turned out pretty good.
Old Jan 9, 2008 | 02:44 PM
SD_MR_FIT's Avatar
i sanded them down, primered it 3 times.(each time sanding down a bit) then i hit it up with 5 coats of black. and then 4 coats of clear.
had it for 10k miles...no chipping or anything. looks like new.
Old Jan 12, 2008 | 06:01 PM
El Chupacabura's Avatar
Do you have to apply a clear coat to the housings ? I want my housings to just be a flat black, so wont putting a clear coat on make them glossier? Or is the clear coat strictly for scratch protection?
Old Jan 12, 2008 | 07:45 PM
smatts's Avatar
It does make it a bit glossy, but I wanted it for the protection. You can do them without the clear coat, but like you said they may chip or damage might show up quicker.
Old Jan 12, 2008 | 09:54 PM
solbrothers's Avatar
i just sprayed the housings with black primer. haas held up for the past few weeks. and i really like the flat black look
Old Jan 14, 2008 | 02:24 PM
i think your local hobby store sells non-glossy (or at least semi-gloss)
clearcoat. just get the enamel kind. should work just fine.
AtticusFit
May 2, 2012 02:29 AM
artlo5er
Nov 28, 2008 10:47 PM
QuickGD3
May 19, 2008 02:33 PM
caie-u
Mar 20, 2008 08:36 PM
Crucio
Sep 16, 2007 04:45 PM
