A few Fit questions
Old Feb 11, 2008 | 07:59 AM
michael49's Avatar
A few Fit questions
I recently took a Fit for an extended test drive and I really liked it but I have a few concerns. I currently have a CRV.
1. I often go camping and bring two kayaks and two bikes. Anyone have any experience with carrying kayaks and bike on the fit? Anyone think I'll have any problems with this?
2. I live in New England and I would like to get the Sport model, but the ground clearance looks really low. How likely is it that I will bottom out with it in snow/mud or on dirt roads?
4. Also, I have heard that the '08 model has a tire pressure monitor that makes getting snow tires a problem - is this true? How about studs? How is the Fit in snow?
4. Is it true that the radio has problems with its tuner in terms of reception?
5. Any other problems that I should be aware of?
Thanks for the input,
Michael
Old Feb 11, 2008 | 08:20 AM
sonicsc1's Avatar
1- i have a hitch mounted bike rack no problems as for the kayaks could just get a roof rack
2-can easly take the side skirts off just screws
4- without tire pressure monitor the light would just be on but im sure the boys on here figured out how to turn if off
5-radio works fine never had a problem
Old Feb 11, 2008 | 08:41 AM
michael49's Avatar
Thanks for the quick reply.
So the Side skirts are easy to remove? Isn't the front "skirting" just as low? - can I remove this as well?
Can you put bikes inside the Fit? Anyone here have a hitch bike rack on their Fit?
Old Feb 11, 2008 | 09:24 AM
Arisenfury's Avatar
1) No experience but I doubt you'll get 2 kayaks inside the Fit if you have two passengers. If you only have yourself then you might be able to get them in along the right side in "long mode". As for bikes there are a couple ways to carry them inside the Fit, if you take the front wheel off you can get them through the side in "tall mode", or lay the seats flat and put them in on their sides.
2) I'm in CT (New England) and I've had no problems with ground clearance and snow. If you're up further north it could pose a problem but I don't see it happening unless you're driving through tons of unplowed snow.
3) IIRC the tire pressure system will make it harder to get it to work with other wheels and tires. But if you get new wheels and snow tires for the snow time you can bypass the system and it just won't work on your snow tires. As for the stock all-seaons in the snow, I only have experience with a modified Fit and the MT. The car is really light so there's not a lot of weight for the front wheels and I could easily break my wheels loose in the snow if I wasn't gentle with the throttle. But it was managable.
4) I have no problems with my reception. If you were in a city then you may have some problems with interference. Usually the biggest complaint about reception is the small antenna which could be switched out for a bigger one if you're having trouble getting a station you like.
5) Enjoying the car too much
Old Feb 11, 2008 | 10:52 AM
michael49's Avatar
Thanks for the reply.
No, I didn't think I could put the kayaks inside the fit. I would put the yaks on top with a rack. I have heard something about a low weight limit though with the fit and I was thinking about the weight of the yaks, plus bikes, my wife (she's barely 100 lbs though!) plus other camping/hiking crap. Think this will be OK?
I probably will end up putting the bikes on a rack, but could I fit two bikes in the back, one on top of the other, with the front tires off? Typical sized mountain bikes.
Can I just put snow tires on and screw the tire pressure monitor system? I don't really care if a "warning" light is on that shouldn't be.
You guys been happy wtih your Fits in general?
BTW, I grew up in CT. I now live near Northampton, MA.
Old Feb 11, 2008 | 11:55 AM
pip_rocks's Avatar
if the majority of us call ourselves "fitfreaks", that should be a testament to our devotion
Old Feb 11, 2008 | 12:00 PM
ive yet to scrape anything and my car is lowered at least -1.5".
no issues with radio receptions on mine.
Old Feb 11, 2008 | 12:01 PM
Firebat666's Avatar
im very happy, no probelms in snow for me no radio issues, good luck in your search!
Old Feb 11, 2008 | 04:28 PM
Snap Fit's Avatar
nope...haahaa. Ummm two kayaks on the roof and easilly two bikes (with released front wheels) easily in the Fit with camping stuff too!
The base Fit is still a good choice, but... either way (i have the sport) and have had very, very few ground clearance issues. I had much more probs with clearance with my previous Civics and new Civics. But sorry...I dont
have experience in your particular conditions.
well we all now this one now and its not a prob for you...so moving on...
Problems...? hmmmm.... I think its less than perfect and stuff but Its still nice and ok reception. I have had worse and better. I think its features kinda make up for it in some ways.
uhhhhhh.... you personally? idunno.... uhhhh it doesnt have tons of
power...but it does extreemely well with what it has
Michael
Oh the rated capacity for the Fit (max load) is 850 lbs which is the same as the Civic and CR-V. you just wont be able to haul as much butt with that much in it.
WELCOME BY THE WAY...
JUST GO BUY ONE...HEEHEE
Old Feb 11, 2008 | 05:00 PM
FITrunner's Avatar
Hmmm I might be in the minority here but you might want to think about keeping the CR-V. The fit is fine and dandy, but if you plan to stick a couple kayaks on the roof, you can say good bye to aerodynamics. Granted its the same with the CR-V, but at least with the CR-V you have a little bit higher HP and torque numbers to compensate.
Old Feb 11, 2008 | 05:16 PM
michael49's Avatar
Hmmmm....anyone have personal experience with this?
Old Feb 16, 2008 | 08:50 PM
Fit_US's Avatar
Choices
I would get a Sport, it's worth the few extra $$$.
My radio reception is only so so, but was crappy on the truck I had before. I just assume it's the terrain I drive.
Old Feb 16, 2008 | 08:59 PM
Firebat666's Avatar
Hey Fit US whre in CT are u from?
Old Feb 17, 2008 | 04:30 PM
Fit_US's Avatar
Couple of towns over...Bristol...Born & Bred.
2 places for you?
like2cycle33
Jul 18, 2018 06:17 PM
pattyobrien3
May 3, 2012 08:56 PM
Dougr320
Sep 25, 2010 01:36 AM
Sugarphreak
40
Feb 20, 2009 10:10 AM
Todd
Jul 27, 2005 05:30 PM
