Sponsored by:
Sponsored by: CARiD
Anybody has this oil leak problem?
Old May 13, 2008 | 01:09 PM
Buktheng's Avatar
I have an 07 Fit Sport Auto and have this oil leak problem that's not really a problem but its like a really slow leak. I see the leak pretty much around the bottom of the radiator where the radiator hose is connected into it. Its so bad that pretty much the oil pretty much covered the up the whole hose and around it and I could see oil like on the bottom of my transmission cover. I can take a towel and wipe it off to clean it up.
I changed my oil recently and it seems like its not a crazy leak because a lot of oil does come out. What do you think could be the problem? Thanks!
Old May 13, 2008 | 08:52 PM
Sloto200's Avatar
I am not to familar with the underside of this car as i just bought mine recently. The first thing off the top of my head was the oil filter. (since it is mounted on the front side of the motor) If it doesnt have a good seal or the seal from the last filter got stuck on the engine, then it is probably leaking...
Old May 13, 2008 | 09:15 PM
cavie187's Avatar
There have been complaints of rocks bouncing around the engine bay and breaking A/C condensers. If the car is prone to debris entering the underside of the engine compartment you may want to consider that as another possibility.
Old May 14, 2008 | 01:36 AM
claymore's Avatar
Are you sure it's oil? That area is where lines to the Auto transmission cooler connect maybe it's auto trans fluid.
Old May 14, 2008 | 08:34 AM
mahout's Avatar
This is a case where immediate attention is required and it takes examination not inquiries here. See your dealer. An oil leak is potentially serious and at leasty the first 36,000 miles is a Honda problem.
Whether its automatic fluid or engine oil is immaterial; finding the source and curing is required.
Old May 14, 2008 | 08:57 AM
binaryh4x's Avatar
If you want to further diagnose, what color is the 'oil'?
Old May 14, 2008 | 09:35 AM
Buktheng's Avatar
The oil is pretty much black from all the residue build up but the oil underneath the transmission is like kinda brownish.
Buktheng's Avatar
I have an appt. with the dealer on Friday but I just wanna know what the problem could be from. Hopefully it fixes my MPG.
Old May 14, 2008 | 01:15 PM
cavie187's Avatar
be sure to let us know what it is when it's fixed.
Old May 14, 2008 | 02:05 PM
gofastredfit's Avatar
From: Hampton Roads, V A U.S., Earth, Milkyway Galaxy
What does the residue smell like?
It'll stink if it's transmission fluid.
Old May 16, 2008 | 04:28 PM
Buktheng's Avatar
Turns out it was transmission fluid leaking. Some of it got into the lower radiator hose so they're replacing it. Those bastards didn't have one in stock so I won't get my car back until Monday. Great!
Old May 16, 2008 | 04:37 PM
Sorry to hear that it's your transmission, but at least you found out b4 something important got damaged!
Old May 17, 2008 | 10:44 AM
claymore's Avatar
Like I said......
Scotty2h
Aug 27, 2015 06:19 PM
Vince_TB
Apr 25, 2014 11:58 AM
Odie
28
Apr 4, 2013 01:43 PM
fhoeft
Oct 19, 2012 01:11 AM
mozarwasagenius
Mar 31, 2009 12:54 PM
