paintinf foglight housing???
Old Jul 12, 2008 | 11:35 AM
AtticusFit's Avatar
painting foglight housing???
was wandering if i should paint housings flat black or gloss black?
Old Jul 12, 2008 | 11:44 AM
ricohman's Avatar
I am also thinking of adding foglights.
What color do they come in?
Old Jul 12, 2008 | 11:45 AM
doctordoom's Avatar
Supervillain
in my opinion, flat black looks better. especially if you paint your headlight housings black too.
Old Jul 12, 2008 | 12:33 PM
KoolMikeSki's Avatar
Flat black!!!!!
Old Jul 12, 2008 | 12:41 PM
solbrothers's Avatar
flat black to match the rest of the grill.
Old Jul 12, 2008 | 01:53 PM
Sugarphreak's Avatar
Push My Button
I painted mine satin black.... just to be different
Old Jul 12, 2008 | 03:19 PM
ascGD3's Avatar
flat black FTW!
Old Jul 12, 2008 | 04:00 PM
c_mack9's Avatar
i went with semi gloss. its almost flat but not quite.
Old Jul 12, 2008 | 05:27 PM
saiko's Avatar
Avid FitFreak Poster
I would say flat black.
Old Jul 12, 2008 | 06:38 PM
cstmFIT's Avatar
flat black
I'm doing this on my next day off, im using high heat flat black.
redrumm's Avatar
id say semi gloss because sometimes the flat black tends to look like its dry.
atleast with semi gloss its not soo bad
Old Aug 3, 2008 | 12:50 AM
shazaam's Avatar
satin is the sexiest black.lol. It's what mine'll be when I actually go out and get some paint.
Old Aug 3, 2008 | 09:45 AM
Rob22315's Avatar
The Honda kit is a satiny black, just like the plastic pieces around the mouth of the grill. I don't think they're painted or taped, just unfinished. I didn't finish mine because they match the surrounding plastic. I just put some Ultima Trim and Tire sealant on them when I detail. Pics here:
https://www.fitfreak.net/forums/fit-...ase-fit-3.html
Sealant here:
Ultima Tire & Trim Guard Plus | Automotive Bumper, Rubber, Plastic Trim Sealant
The sealant is a little pricey but the bottle goes a really long way because so little is used to seal and protect.
Old Aug 3, 2008 | 03:00 PM
mdm427's Avatar
I used Dupli-Color's black bumper coating. It has a satin finish, and is supposed to be more durable than regular paint. I have about three or four thousand miles on the car since painting them, and still no chips. IMO, it matches the grill perfectly. It comes in a few different colors, so be sure to get the black if you go this route.
Just use a Scotchbrite pad or fine grade wet sandpaper to scuff up the housings to give the paint something to bite into. I wanted to use Dupli-Color's adhesion promoter, but the can wouldn't spray. Neither would the second one that I exchanged the first one for, so I just gave up on it.
Old Aug 3, 2008 | 07:54 PM
trancedsailor's Avatar
I'm going to paint mine the same red that my emblems are ;P
Old Aug 3, 2008 | 09:08 PM
AtticusFit's Avatar
decided to just get blk bezels instead of painting that way i could go back factory if i ever decided to go back OG.
thanks for all the info guys.
Old May 2, 2012 | 02:29 AM
sloganmartin's Avatar
Where did you find the black housings? I'm thinkining about buying them for the same reason of possibly going back original. Is your fit a base or sport model?
dpmason
Aug 6, 2014 03:38 PM
Ninja Nips
Mar 2, 2011 10:06 AM
nosewitdot
SoCal Classifieds
Jan 27, 2011 03:16 PM
AtticusFit
15
Aug 23, 2008 11:44 PM
los_creeper
371
Jun 30, 2008 09:22 PM
