I've searched ( skunk2 short shifter)
Old Jul 21, 2008 | 10:28 AM
Beretta's Avatar
Well I took apart my console and everything yesterday, but i can't get the damn shift cable unhooked or unlocked, how do you do it? D: it says to move it counter-clock wise but it won't budge
Old Jul 21, 2008 | 11:42 AM
drzenitram's Avatar
turn it harder. lol. it's really stuck in there.
i was thinking the same as you, but it's really just a matter of force. there's not a lot of leverage to work with, so just keep trying.
Old Jul 21, 2008 | 01:22 PM
honda_david's Avatar
you suck beretta haha jk
Old Jul 21, 2008 | 03:19 PM
Beretta's Avatar
but what part do i turn the back part with the little lever type thing? or the front part?
Old Jul 21, 2008 | 06:06 PM
kancerr's Avatar
if i remember right the end of the cable has two things that stick out where it locks in that you can twist...
Old Jul 21, 2008 | 10:19 PM
Beretta's Avatar
yea guess i was being a girl about D:
i got it thanks guys.
Old Jul 23, 2008 | 04:13 PM
Beretta's Avatar
how the hell do you get the little plastic thing off the bottom of the shifter D:
Old Jul 23, 2008 | 04:15 PM
yeamans17's Avatar
Use a pair of pliers or vice grips and grab it gently so you don't mess it up and twist it to the side it should pop off.
Old Jul 23, 2008 | 04:35 PM
kancerr's Avatar
yep...how many days have you been working on this? haha....
Old Jul 23, 2008 | 05:03 PM
Beretta's Avatar
on and off bro, but i will finish it today, i so got the bushing onto the extension, now the nexxt problem, is the extension suppose to be tight onto the shifter? and I been tryint but i can't get it to tighten on their for crap. help!
Old Jul 23, 2008 | 05:11 PM
kancerr's Avatar
you have aim i can help you step by step and talk instantly if you need help.
it should be "snug" not super tight. you need to use loctite on the set screws for the extension also. do you have any loctite? i used the medium strength, that way if i ever need to take it off i can take it off with a little force and not damage anything. you might also notice that the set screws go in at a downward angle, make you you screw em in properly so you dont strip out the set screws or the hole.
if you have aim gtive me your screen name and i can answer any questions you might have.
Old Jul 23, 2008 | 05:18 PM
Beretta's Avatar
pm'd sir i still can't get it
Old Jul 23, 2008 | 08:34 PM
Beretta's Avatar
success! though its not as short as i thought it would be (not suprised since i read this many times), it does feel a bit sporty'er and more rough which i like =)
Old Jul 24, 2008 | 10:46 PM
Beretta's Avatar
well the extension wiggles a little bit is that normal? or should i redo the set screws?
pearl
May 24, 2014 07:31 PM
MemphisFit
Jul 25, 2008 02:19 PM
ascGD3
Jul 11, 2008 01:31 PM
t3chn0rav3rb0y
Dec 3, 2007 01:15 AM
Skunk2TS
Aug 28, 2007 10:11 PM
