Fog Lights
Old Aug 19, 2008 | 03:33 AM
sbualuba's Avatar
Question Fog Lights
I have a ssm base fit, you couldn't put oem sport fog light housings and lights on could you?? or it the bumper completely different??
Old Aug 19, 2008 | 03:39 AM
Drag0na5h's Avatar
You can get a decent set from Ebay, comes with templates to cut out holes in your bumper and all the necessary wiring. I found if you pull down the driver side wheel well cover you can see a small hole covered up by a rubber grommet, not used, that you could run the wires into the cab by. Using a dremel to cut out the bumper made it very easy, just watch out for hot melted rubber flying into your arms and face.
Old Aug 19, 2008 | 03:35 PM
Rob22315's Avatar
Yes you can. In fact, Honda sells a kit to do just that. I did it on my Base fit, here's the thread:
https://www.fitfreak.net/forums/fit-...-base-fit.html
Old Oct 17, 2009 | 09:40 PM
Fat Ping Cat's Avatar
Bthasht
Sep 16, 2011 11:20 AM
jvolivier
Feb 4, 2010 01:15 AM
Blueputtputt
Feb 26, 2009 07:26 AM
BenDF
14
Sep 2, 2006 05:29 PM
fastredcar
Jul 29, 2005 03:32 PM
