okada plasma direct
Old Sep 1, 2008 | 02:57 AM
bbpGEftmfw's Avatar
okada plasma direct
Hey guys, does anyone know if they make these for the fit. I know the s2000 and k20 guys have them and they do produce a better than stock spark. Im not looking for a power increase per say, but the more efficient quicker burn would be nice.
Old Sep 1, 2008 | 11:54 AM
Sugarphreak's Avatar
Push My Button
Could try them, the Fit already requires a pretty spanky plug; Iridium tip only I believe.
Old Jan 3, 2014 | 12:09 PM
kylerwho's Avatar
spoon fed
I'm bumping this crazy old thread to see if anyone is running these?
I see they carry a grand price tag without any enhancement aside from reliability.
Old Jan 3, 2014 | 05:37 PM
13fit's Avatar
they are useless from a performance -> value point.
You can get a better spark from using a slightly bigger sparkplug gap and using plugs that are one heat range colder.
Our stock plugs are Denso 20/NGK 6 heat range. my plugs are the stock Densos available for a honda S2000 2.0 liter (01-05?)
spend the grand on something else. significant other, or kids.
Old Jan 3, 2014 | 09:48 PM
kylerwho's Avatar
spoon fed
Im just reading about all these members having coil pak issues and mine finally just crapped out. I have a spare set of cbr600rr coil packs sitting at home and im tempted to give those a try.
Old Jan 3, 2014 | 10:44 PM
13fit's Avatar
those coils are probably not the correct spec, even if they physically might fit.
Dwell time and the coil spec may vary too much and end up either running way too hot or not hot enough of a spark.
It would be a great alternative combined with a tuning solution, as those CBR coils must deal with more heat and much higher rpms. They would be VERY reliable in our cars if they functioned!!
Old Jan 3, 2014 | 11:29 PM
kylerwho's Avatar
spoon fed
I'm sure there is a way to figure that out with flashpro
Old Jan 4, 2014 | 05:04 PM
TPColgett's Avatar
Coils will die, but it's like $240 for OE replacement ones. They HAVE been revised since the ones that came on our GD's so the reliability is MUCH better. Also, if you swapped to IK-22 plugs, they should be checked, as the gap can wear AND they can come loose in the head... Either of which puts more stress on the coils and can cause them to go sooner.
Old Jan 4, 2014 | 06:22 PM
kylerwho's Avatar
spoon fed
I was looking and the coils sit rather close to the exhaust. Do you think under high load conditions the heat could break down the epoxy inside the coil?
Old Jan 4, 2014 | 06:29 PM
TPColgett's Avatar
I totally think they are effected by the heat, especially if you run a header. It's the reason i had mine ceramic coated and am considering a bracket setup for a heat shield...
VelvetB
May 11, 2016 06:59 PM
kustomimports
Nov 11, 2014 06:22 PM
Psycho_FIT
Jul 4, 2010 10:00 AM
sbualuba
17
May 5, 2010 12:59 PM
Wave
Jan 16, 2009 01:08 PM
