Breather hose?
Old Sep 2, 2008 | 04:30 AM
ezduzit's Avatar
Breather hose?
Instead of using one of those little filters on the end of the breather tube, I would like to vent to my homemade intake with a hose.
Where can I get the right size and type of hose to connect the tube to my SRI?
Old Sep 3, 2008 | 04:01 PM
kancerr's Avatar
i've been wondering this too. i need to redo my line...i went to several stores and cant find the hose! home depot might have them?
Old Sep 3, 2008 | 09:19 PM
kancerr's Avatar
i went by home depot today and they do have the hose. not sure on the size but i can get the size for you tomorrow after work.
Old Sep 6, 2008 | 05:52 AM
ezduzit's Avatar
thanks, I'll go by the local home depot and check it out.
Old Feb 10, 2011 | 09:40 PM
gloryhound's Avatar
does anyone know the size tube i would need for a vacuum tube, instead of using a breather.
Old Feb 10, 2011 | 11:41 PM
kirko's Avatar
Go to autozone or advanced, and ask for vacuum line, not hose. Vacuum line is typically a little stretchy, and you can get some up to 3/8 inch size. Use some silicone spray and itll go on.
Old Feb 11, 2011 | 11:57 AM
gloryhound's Avatar
thanks for the reply kirko, so the 3/8 of an inch over 5/8?
Old Aug 4, 2011 | 01:21 AM
GoFits's Avatar
Where is a good place to get rubber plugs and grommets for the intake? My crankcase vent hose and plug/grommet have stretched and worn out a bit. I have tried hunting down the part numbers but have found nothing really useful. They don't often have the dimensions.
Is autozone/advance/oreily the best option? I get so sick of how UTTERLY useless the guys/gals at these shops are.
Old Aug 4, 2011 | 02:47 PM
Koi's Avatar
Koi
You mean like the grommets for the intake temperature sensor? You can get oem replacements from places like bernardi parts under parts > air cleaner
The plug/grommet for the breather hose is also on the same page, #1
3K9
Nov 13, 2015 08:57 AM
wzlfit
Apr 4, 2015 06:26 PM
s0x
Oct 13, 2014 05:41 AM
bdogpot
Nov 27, 2012 09:31 AM
Dwalbert320
Oct 3, 2012 09:49 PM
