How do I add accessory wiring
Old Sep 6, 2008 | 06:46 PM
jimnorine's Avatar
I want to hard wire my GPS and my Sirius receiver. I would like to power them both from the wire that goes to the lighter outlet. I can't figure out how to remove the panel under the dash that hides all the wiring. Any ideas? Thanks, Jim
Old Sep 6, 2008 | 10:56 PM
jaebee's Avatar
there are two circles to turn, and it pops off. then you can access the fuse box. i would suggest using an add a fuse, to protect your stuff.
Old Sep 7, 2008 | 01:51 PM
jimnorine's Avatar
Yeh, I know about the fuse box cover. The panel I want to remove is the horizontal one under the dash that hides the wiring.
Old Sep 8, 2008 | 03:42 PM
raltiero's Avatar
I believe that there is a twist piece underneath and to the front. Twist to unlock and then gently pull forwards. Look at step #9 for instructions on how to remove. http://www.collegehillshonda.com/ins...8/AII38214.pdf
I purchased this http://www.tss-radio.com/cigarette-l...er-p-4057.html to power my GPS. I purchased these fuses http://www.accessafuse.com/access.htm to power it. I removed the driver's kick panel to locate a place for a ground. See step #21 from the above instructions.
For the Sirius Satellite radio I purchased this http://www.tss-radio.com/sirius-vehi...it-p-4438.html to hardwire it. I use another of the fuses and tapped the ground wire that I ran for the GPS. I hid the extra wire from the antenna and the power unit inside of the center console right near the cup holder cubby area.
Old Sep 9, 2008 | 01:31 AM
jimnorine's Avatar
Thanks, raltiero. That's exactly what I needed. Jim
SilverEX15
Feb 12, 2019 07:25 AM
billydee203
Jan 18, 2016 04:02 PM
m_x
Jan 16, 2016 03:55 PM
SilverEX15
Aug 25, 2014 08:29 AM
Bennett0415
Aug 17, 2012 12:24 PM
