How do I add accessory wiring
I want to hard wire my GPS and my Sirius receiver. I would like to power them both from the wire that goes to the lighter outlet. I can't figure out how to remove the panel under the dash that hides all the wiring. Any ideas? Thanks, Jim
I believe that there is a twist piece underneath and to the front. Twist to unlock and then gently pull forwards. Look at step #9 for instructions on how to remove. http://www.collegehillshonda.com/ins...8/AII38214.pdf
I purchased this http://www.tss-radio.com/cigarette-l...er-p-4057.html to power my GPS. I purchased these fuses http://www.accessafuse.com/access.htm to power it. I removed the driver's kick panel to locate a place for a ground. See step #21 from the above instructions.
For the Sirius Satellite radio I purchased this http://www.tss-radio.com/sirius-vehi...it-p-4438.html to hardwire it. I use another of the fuses and tapped the ground wire that I ran for the GPS. I hid the extra wire from the antenna and the power unit inside of the center console right near the cup holder cubby area.
Bennett0415
Aug 17, 2012 12:24 PM
