removing stock intake box bracket
Old Oct 26, 2008 | 06:26 PM
xonexlifex's Avatar
i was just wondering bec i just chopped my hps CAI to make it a SRI bec i hated the lack of torque and was wondering if anyone found an easy way to remove that stock air box bracket underneath thats bolted to the engine down there, if i could find a easy way to take it off than id be able to put the intake filter a little bit more into side so it doesnt suck as much hot air
Old Oct 26, 2008 | 06:29 PM
kylerwho's Avatar
spoon fed
nice rachet with a breaker bar and bloody knucles worked for me.
Old Oct 26, 2008 | 06:38 PM
xonexlifex's Avatar
hahahahaha where did you come from tho? the top of the engine bay or the wheel well or under the car?
Old Oct 26, 2008 | 06:44 PM
kylerwho's Avatar
spoon fed
i came through the top. its an awkward position but you have to just muscle it out.
Old Oct 26, 2008 | 07:48 PM
xonexlifex's Avatar
ok ill see what i can do, i think i tried and it didnt work, did you remove anything?
Old Oct 26, 2008 | 08:31 PM
kylerwho's Avatar
spoon fed
took out the whole stock intake and battery. then took off the bracket but left the bolts in. its a tricky process
Old Oct 26, 2008 | 09:07 PM
xonexlifex's Avatar
i got it! i went out to the garage and got a 12mm wrench and got the front one loose and then turned it turn by turn until it came out, as soon as you break loose the other one you can loosen the bolt with your fingers and presto its off, it feels like the bolts are in the there hella deep when you undoing the first one but once you get that one off than its a piece of cake, thanx for the info, it helped me. now my intake filter is snugged down inside that opening and looks way better!
Old Oct 26, 2008 | 09:32 PM
petwhookie's Avatar
pics please!!
Old Oct 26, 2008 | 09:43 PM
kylerwho's Avatar
spoon fed
here to help.
Old Oct 27, 2008 | 01:17 AM
xonexlifex's Avatar
Originally Posted by petwhookie
pics please!!
inspire007
Jan 29, 2013 10:03 AM
Leets
Oct 24, 2010 08:34 PM
ThEvil0nE
Oct 15, 2010 12:22 PM
Fitguy07
Aug 10, 2009 07:10 AM
Rod2Rice
Jul 24, 2008 11:06 AM
