PRM's intake dyno figures
Old Nov 6, 2008 | 09:59 PM
PRM's Avatar
PRM
dyno results are in
O.K we dyno'd Kifu's car tonight, you can consider this an independent test because i was not there.
i only have the figures for you, should have the graph soon, kifu has a print out, so you may see it tomorrow.
base line whp = 94.1
base line torque= 91.
PRM intake whp = 99.4
PRM intake torque = 95.9
a solid 5 hp & 5 ftlbs of torque to the wheels.
should make even more power with the exhaust- stay tuned !!!
Gerry
Old Nov 6, 2008 | 11:27 PM
TurboManGT's Avatar
Sweet!!! This should bring you more business Gerry!!!
Old Nov 7, 2008 | 04:59 PM
kifu's Avatar
Blue Line is the stock air box, red line is the PRM intake
Old Nov 7, 2008 | 05:17 PM
cojaro's Avatar
Looks like a solid 5ft-lbs and 5whp throughout the entire powerband. That's a-nice! =]
Old Nov 17, 2008 | 05:23 PM
DrPhyzx's Avatar
It's nice to see some results but I wish both plots were over the full RPM range. I'm always a little suspicious when dyno testing shows constant improvement over the whole range since that often indicates a change (correction factor) that is giving a false result. For any significant change you can make to intake or exhaust, a test over the full range will always show some clear variation in improvement with RPM. I would hope to see that if both tests were run from 2K to redline.
Old Nov 17, 2008 | 07:36 PM
doctordoom's Avatar
Supervillain
that is very insightful
Old Nov 17, 2008 | 07:49 PM
zakurie's Avatar
I'd like to know if there is a difference in fuel economy.
Old Nov 17, 2008 | 11:15 PM
TurboManGT's Avatar
That would depend on the mods and the driver.
Kyokutou23
Apr 24, 2009 09:36 AM
panda1314
Apr 16, 2009 09:58 AM
WRLEO
Mar 8, 2009 09:19 PM
j6kwok
Jan 24, 2009 12:08 PM
Sam Misled
Sep 21, 2008 01:07 PM
