(Question) removing tailiights
Old Dec 12, 2008 | 04:32 AM
808tradegy's Avatar
I was wondering is there any other way I can replace my stock tailights without removing the rear bumper? if so how will i do it... thanks
Old Dec 12, 2008 | 09:48 AM
NBPturtle's Avatar
Im pretty sure there is....Theres a thread around here that talks about it I think.
Old Dec 12, 2008 | 11:41 AM
GD3_Wagoon's Avatar
Thumbs up
yes, but you gotta make sure your exhaust is cold when doing it otherwise you may burn yourself
if you have a screw driver with at least an 8 inch shaft then you can just reach up from under the rear end of your car and unscrew the screw holding the bottom of the taillight in place -- one of them is right above your muffler. you can check koolkevin's write-up for pics. he installed my LED tails about 5 months ago and i haven't had any problems with them yet
Old Dec 12, 2008 | 12:00 PM
Fitcapo's Avatar
Its easier to just remove the bumper. The bumper comes off with only a couple tabs removed.
Old Dec 12, 2008 | 01:05 PM
MNfit's Avatar
Yea you can, I did a DIY on the install of my JDM lights without removing the bumper.
Old Dec 12, 2008 | 04:33 PM
sevenaprils's Avatar
Personally I thought doing it without removing the bumper was super easy. Can't see how removing the bumper, even if its a few tabs and some pulling, could be easier... but to each his own.
Old Dec 12, 2008 | 09:07 PM
ds62987's Avatar
When I did mine I removed the bumper. Its not hard to take off at all, hondafittuner.com has a write-up on this in the forums that will help.
Old Dec 13, 2008 | 01:20 AM
808tradegy's Avatar
thanks guy. but i was frighten about removing my rear bumper. idk i'll make decision later. hmmm... how long did you guys replace your tailight without removing front bumper.? i did not like removing my rear bumper because i might break the tab or something.
Old Dec 13, 2008 | 02:17 AM
ds62987's Avatar
Sure, no problem. I was afraid of that to, but once I started doing it turned out to be really easy. Whatever you end up doing I hope it goes well.
Old Dec 13, 2008 | 02:27 AM
Fit4Trav's Avatar
Removing the rear bumper makes it very easy to access everything, and its not all that hard to remove
Merriweather
Mar 25, 2014 09:05 AM
Dix GD3
Feb 12, 2013 08:02 PM
Marrk
Dec 18, 2010 08:48 PM
Edison Carasio
Aug 28, 2009 03:12 PM
moondog
Mar 24, 2007 06:03 PM
