?uestion about HID kits
Old Apr 26, 2009 | 11:03 AM
DrKelso's Avatar
Can you take any temperature bulb and plug them into any HID kit as long as the amperage/wattage/voltage/whateverage are correct? Or is the ignitor specific to those bulbs?
Also, The HID kit I have has OEM style bulbs (H4?) on them, but if I were to do a retrofit, could I take different bulbs that would fit my projectors and just plug those right in?
Old Apr 26, 2009 | 11:49 AM
1FiTpINOY's Avatar
You would need get an adapter for the different sized bulbs. The connection is different for every bulb.
Old Apr 26, 2009 | 12:41 PM
DrKelso's Avatar
Where could I get one of these adapters?
Old Apr 26, 2009 | 01:24 PM
Will I Am fit.'s Avatar
Formerly "bitoy"
If you are to use a projector that fits on a D2S bulb and use your current ballast you would need an amp connectors you can get it from this site The Retrofit Source (U.S.) - HID Projector Retrofit Kits, Retrofit and HID Componenents, Projectors Lens, Wiring Harnesses, Shrouds and more!
madtodaimax
Feb 26, 2014 04:22 PM
samwell
Jun 10, 2010 01:38 AM
YeeFit
Mar 28, 2008 11:28 PM
Crawly
Jan 28, 2008 12:50 PM
SoccaBoi
Oct 18, 2007 10:49 AM
