AXLE POPPED OUT... Can someone help me at LAX????????
Old Feb 18, 2010 | 01:38 AM
Mitsukeru's Avatar
AXLE POPPED OUT... Can someone help me out please?
Old Feb 18, 2010 | 01:47 AM
crash001's Avatar
WTF how did it pop out call aaa
Old Feb 18, 2010 | 02:07 AM
thefit09's Avatar
Probably putting in new springs. Happened to me too b/c i've never done a spring install before.
If you can't work it back in, you'll need to break the clamp on the cv boot, pull back the boot, and then line the bearings up into their slot. That's what I had to do. It sucks, but at least I learned from my mistake!
EDIT: If you do this, please be sure to repack with the appropriate grease and install a new, appropriate clamp.
Old Feb 18, 2010 | 05:00 AM
vinn's Avatar
Um, ask a friend or someone to help you next time. I cant really help you with that. Sorry!
anyways, yeah my axle popped out too when i did my install
Old Feb 18, 2010 | 06:08 AM
cd4ag's Avatar
search the forum there was a couple of threads with a bunch of hints 'n tips on getting the axle back in.
Old Feb 18, 2010 | 11:15 AM
Mitsukeru's Avatar
Is there a diagram i can see to understand which one is the boot and hat tools I'll need?
Old Feb 21, 2010 | 02:00 PM
OneStopCustoms's Avatar
pictures?!?! Its not much work, you can do it yourself. I did it with my brother on a eg civic I had a while back. I'm sure there's diagrams around the internet. check here to see if you can find a diagram. http://www.hondaautomotiveparts.com/
Old Feb 21, 2010 | 06:29 PM
ascGD3's Avatar
I remember when this happened to me, had to take it to a shop. Learned from my mistake. Good luck!
Old Feb 21, 2010 | 07:08 PM
thefit09's Avatar
The boot is the ribbed rubber fitting that goes over the two axle pieces. You only need something to cut the clamp (we used pliers/wire cutters) and whatever tool is required to put on the new clamp.
kentkanaya
Nov 1, 2019 12:01 AM
tekmcleod
Oct 26, 2016 02:38 PM
jnesselroad
May 28, 2011 08:10 AM
tonyd3773
15
Mar 4, 2008 06:21 PM
tainogunslinger
Sep 18, 2007 08:41 AM
