Help me setting Fcon mini for FIT turbo
Old Feb 28, 2010 | 10:33 AM
ku8o's Avatar
guyz
i need help
few days before i purchased Top Fuel Turbo Kitt Zero 1000
which comes with HKS Fcon mini as a piggyback
do any of u use this Fcon mini ?
some says it can be set n map manually
i need to know how to sett manually on fit AT turbo
thx before
Old Feb 28, 2010 | 10:42 AM
JDMchris.com's Avatar
I run THIS
As far as I know, Fcon can only be tuned by authorized HKS dealers that have the software, but that is here in the states.
Old Feb 28, 2010 | 11:38 AM
dewthedew's Avatar
As far as I know hks makes terrible piggybacks.. sell it and buy an aem f/ic and call it a day.
Old Mar 3, 2010 | 05:56 AM
ku8o's Avatar
sharing slliped cvt using turbo kitt:
finally when installation completed
with a default setting of fcon mini i feel very exited
but as the the drive began
from "D" clutch spontaniously changing to "S" mode ,full throttle
the problem occur :
my CVT couldnt hold enough turbo power within
@4000-5000 RPM, cvt would not change gear
the RPM pointer just idling and does not increase any speed
F*CK....
i had to uninstalled those turbo's yet only 1 day age on my car
Old Mar 4, 2010 | 11:56 AM
NIGHTHAWKSI's Avatar
the problem occur :
F*CK....
i actually just bought this turbo kit as well.
chance you have a wire pinout for the hks fcon mini?
also, you installed this on a automatic tranny?
the only problem you had was the tranny couldnt handle the extra power?
anythign else important?
Old Mar 5, 2010 | 01:42 PM
jazzista's Avatar
Hi there,
would any of you who bought the kit telling me where can I find it?
TIA
Old Mar 5, 2010 | 02:49 PM
i got mine off ebay. found it for a great deal. couldnt turn it town.
you can buy it new here:
Top Fuel Bolt-on Turbo Kit for Honda Fit GD3- Fortyone Automotive Limited
but its ALOT of money.
for the cost id suggest greddy or hks since they come with intercoolers.
Old Mar 5, 2010 | 04:26 PM
jazzista's Avatar
Thank you, I'm "testing water" for something for I-DSI. Don't know if HKS/Greddy offer something for such engine (ecu tuning included).
Old Mar 23, 2010 | 11:38 AM
ku8o's Avatar
say
do any of u know if this fcon mini (which comes with turbo kitt for fit )
can also be used to another car ??
im planning to sell it
someone asked me, could it be used to another car as a piggyback ?
Old Mar 24, 2010 | 07:16 PM
kennef's Avatar
is this unit a piggy back? among the jdm junk that hks makes, their fcon v pro is a stand out for actually being a legitimate ECU. has good resolution just pricey and limited to "pro tuners" which meant it was never widely accepted.
good luck with sale, whoever buys the unit will probably have to buy a harness that is appropriate for their car.
Old Apr 3, 2010 | 11:48 PM
ku8o's Avatar
you got that right
i try to sell it but still no one bother even to call
most of us here dont really know fcon mini
Old May 1, 2010 | 07:01 AM
elextricy's Avatar
good luck bro kubo..
Old Oct 13, 2010 | 12:30 PM
ku8o's Avatar
hehhehe ketemu disini
uda beres b ro akhirnya
Old Oct 13, 2010 | 02:10 PM
Itsslow's Avatar
Ku8o if you ever go on vacation to the united states swing by Miami fl, I will take that headache off your hands ca$h money. Then you can spend it on hookers, even though you probably got tons of them over there :/
Old Oct 13, 2010 | 02:11 PM
DiamondStarMonsters's Avatar
What sort of options or interface do you have with it?
Can you post a screen shot? Or is all you have just the hardware and no cables/tuning software to access it?
Are those Blue squares with the yellow circles dials to adjust settings? I can't really see what we are looking at..
Old Oct 13, 2010 | 02:55 PM
i also have the fcon mini. exact same one that the OP has.
programmed for a honda fit turbo kit used with OEM injectors (185cc) and a garrett GT journal bearing T25 flanged turbo.
i have a wiring diagram to go with it as well.
if your realling interested in buying it, ill sell it for rather cheap since its of no use to me.
Old Oct 13, 2010 | 03:39 PM
Itsslow's Avatar
Well there is a possibility, does it have an intercooler, and is the system plug-n-play.
Old Oct 13, 2010 | 03:57 PM
i was referring to selling just the HKS fcon mini....not the entire turbo kit
but it was programmed for a non-intercooled turbo system, and it is not plug and play.
Old Oct 13, 2010 | 04:17 PM
Itsslow's Avatar
Ahh I see how I created some confussion. I wouldn't need that f-con unit, but I am looking into getting a system
Old Oct 16, 2010 | 02:18 AM
Originally Posted by armandjones82
I think that having a good installation kit would be a key here. I don't know if this would really even help you out but try some branded parts like KYB and the like in order to make your turbo kit running smoothly. Hope that all will be well by now.
Clearly... We should use suspension components in our turbo kit?
ku8o
Jun 22, 2010 09:17 AM
trinisir
Mar 23, 2010 03:55 AM
1990hondahf
Jul 7, 2009 12:25 PM
CrystalFiveMT
Nov 26, 2008 07:50 PM
200psGD3
19
Feb 17, 2008 12:07 PM
