Problems with KWSC
Old May 14, 2010 | 12:24 PM
da9r00d's Avatar
Problems with KWSC
has any had any problems with the supercard for the KWSC? or the MAP sensor stabilizer? i just threw a P107 Code (Low MAP voltage). i cleared it and it ran fine. but now i cant floor the pedal, it bogs out like its not getting fuel or cutting out. but it i drive with the pedal 75% it is fine.
Old May 14, 2010 | 12:25 PM
JDMchris.com's Avatar
I run THIS
You re-check your connection?
Also did you call or email KW? They would know better than anyone on here.
Old May 14, 2010 | 12:33 PM
da9r00d's Avatar
i checked the connections. i called and left a message
Old May 14, 2010 | 12:34 PM
da9r00d's Avatar
im on AOL IM with them now
Old May 14, 2010 | 01:09 PM
hondaFORlife's Avatar
Good luck man
Old May 14, 2010 | 01:47 PM
FELIXY69's Avatar
the computer isnt reading and making it run too rich ?
did you try re-setting ur computer?
Old May 14, 2010 | 02:02 PM
da9r00d's Avatar
yeah, tried it. KW said to bring in the Electronics for warranty.
Old May 14, 2010 | 05:00 PM
Koi's Avatar
Koi
I had the exact same P0107 problem pop up, made my car go to limp mode for a little while. Thought it was the MAP stabilizer but it was actually the wire connection going bad.
Electrical connections looked fine, but I found out that moving around some of the wires would cause the engine to stall/die, throwing the MIL in the process. Turns out that where the MAP stabilizer connects to the middle wire of the MAP sensor plug, the wire was just about to break (and it did break once I found out).
Try moving your wires around and see if it causes problems.
Old May 14, 2010 | 08:41 PM
da9r00d's Avatar
i changed the connections for the MAP, didnt help. so im going to bring the MAP stabilizer into KW andhave them look at it.
i cant rev hard at full throttle, but if i use like 50-75% throttle it runs fine.
i had scene an older post u posted, how much did you pay for the new MAP sensor?
Old May 14, 2010 | 08:46 PM
Koi's Avatar
Koi
37830-PNC-003
Bernardi Parts has it for sale at ~$54 before tax+s/h... I bought mine for around $70-80 shipped back then.
Old May 14, 2010 | 09:56 PM
lcq4blackstar's Avatar
Hope you get it all worked out!
Old May 17, 2010 | 02:11 PM
da9r00d's Avatar
i changed the Map stabilizer, no difference. going to change the Map sensor 2morrow
Old May 18, 2010 | 08:18 PM
da9r00d's Avatar
changed the MAP sensor and the MAP stabilizer.... No FIX. Going to check the wires 2morrow.
Thanks to KraftWerks (OJ jr) for swapping out the Map stabilizer with out any issues.
Old May 18, 2010 | 09:06 PM
Wave's Avatar
Tagged for interest...
Old May 19, 2010 | 03:21 PM
da9r00d's Avatar
i changed the MAP sensor and the KWSC MAP stabilizer... No fix. i took off the Map stabilizer and the car runs fine
Old May 19, 2010 | 03:35 PM
da9r00d's Avatar
im going to try a MAP Bypass Valve
Old May 19, 2010 | 07:09 PM
I run THIS
Did you ask KW if this would be wise? I still think it is a connection problem. This is what it continues to sound like. Do you possibly have it connected backwards?
Old May 19, 2010 | 08:01 PM
da9r00d's Avatar
The MSS is installed like in the instructions, i just talked to KW. im going to take the car in and have them look at it.
Old May 22, 2010 | 05:52 PM
da9r00d's Avatar
KraftWerks saved the day... They fixed my issue. it was the Supercard (My fault, i got it wet). they helped me out and they fixed it. car runs great. now im going to switch out to 10psi.
Big THANKS to OJ jr and OJ @ KraftWerks for helping me out. Best customer service by far from any company I've ever done business with
damoaten
Aug 21, 2024 04:17 AM
doctor J
Oct 22, 2016 11:29 PM
De36
Jun 2, 2016 06:31 PM
Koi
May 8, 2011 08:24 AM
Koi
Aug 16, 2010 09:35 PM
