K20Z3 swap into my AT fit?
Old Jul 15, 2010 | 04:49 AM
faifai1211's Avatar
just wondering will there any problems with this set up to my AT fit? or are there anything i need to be aware of?
Engine
Transmission
shifter assembly and cables
throttle cable
fuel line
brake booster line
purge line
clutch lines from master to slave cylinder
high pressure power steering hose
power steering return line
ac line from compressor to condenser
axles
radiator and fans (stock will fit but need trimming)
upper and lower radiator hoses
any comment will help thank you !
Old Jul 15, 2010 | 04:51 AM
DreaMv's Avatar
dont forget the m/t ecu andd pedal assembly!
Old Jul 15, 2010 | 04:52 AM
faifai1211's Avatar
so basically everything its good to go, just the two missing parts you mentioned? ^^
Old Jul 15, 2010 | 04:53 AM
DreaMv's Avatar
you should go to fitswap.com
or search some of the K builds here on fitfreak and send those members a PM
Old Jul 15, 2010 | 05:02 AM
faifai1211's Avatar
sorry just a quick question .... how about the brake system upgrade? should i upgrade just the front brake to a bigger one? or do convertion to rear brake disc for the rear??
Old Jul 15, 2010 | 04:05 PM
feared's Avatar
you'll need MT cluster and ecu, and then the k20 ecu, run dual ecu's /w kpro.
since there's mroe weight, upgrade the brake system while ur at it, rotors, pads, lines, and if you need more, then get a bbk and/or rear brake conversion.
hasport has a k-series mount conversion, and you'll need a custom header
you'll also need to notch the subframe for transmission mounting
post pics of the build if u can, im sure people would be interested in the progress/build
91CRXisGo
Feb 5, 2014 08:36 AM
k-alt
18
Mar 29, 2011 09:29 PM
FELIXY69
Jul 29, 2009 10:15 AM
kobashi
Sep 10, 2008 11:12 PM
blacksirek
Mar 28, 2006 03:21 AM
