Head Up Display
Old Jul 16, 2010 | 09:12 PM
dll932's Avatar
Head Up Display
Heads Up Display MPH 300Z 350Z 370Z ECLIPSE TURBO: eBay Motors (item 110552063405 end time Jul-26-10 15:25:15 PDT)
I've been wanting one of these for a LONG time. They make them in MPH or KPH versions and direct-wire or OBDII connect versions. My only concern is whether the OBDII version will work with my 2010 Fit, since my PLX Kiwi won't. Anyone familiar with this unit?
Old Jul 16, 2010 | 10:01 PM
Krimson_Cardnal's Avatar
Not sure what you're gaining. Trick, yes, but how do you fasten all the gear to the dash. Those Kiwi's sorta look like the same thing.
Get a Scan Gauge if your technically curious. Lot's more info/use in diagnosing problems.
Old Jul 16, 2010 | 10:27 PM
Occam's Avatar
If you have an iPhone, there's an app for that ;-)
Old Jul 17, 2010 | 09:00 PM
dll932's Avatar
Velcro! Anyhow, it's nice to see stuff without having to look down.
Old Jul 18, 2010 | 12:11 AM
Interested to know how this works out for you. Do you know of any other heads-up display units??? Keep us posted.
K_C
Old Jul 18, 2010 | 02:13 PM
dll932's Avatar
Yup-same guy sells a few, check them out on Ebay.
Old Jul 21, 2010 | 03:43 AM
chrisng's Avatar
scanguages are cool, but i ended up with a dash hawk - doesn't work on the fit. but it tells you absoluetely EVERYTHING about a car.
Old Jul 21, 2010 | 08:24 PM
dll932's Avatar
Got a link? Do you know why it won't work?
Old Aug 1, 2010 | 04:42 AM
av911's Avatar
Exactly why I love my 8th gen Civic. The speedometer is in the perfect position.
Old Aug 1, 2010 | 02:47 PM
dll932's Avatar
My 60 Dodge Phoenix had a see-through speedo on TOP of the dash which was great.
http://www.seriouswheels.com/pics-19...Phoenix-re.jpg
http://www.foundationpc.com/brochure/60dartad.jpg
Hard to believe this was a compact.
Old Aug 10, 2010 | 06:52 PM
Bohemian's Avatar
I went ahead an bought one of these. H.U.D HUD MPH head up display DASH CLUSTER SPEED: eBay Motors (item 110569652900 end time Aug-15-10 08:29:35 PDT)
It wouldn't work, so I contacted them and followed their instructions for resetting and trying to get it to work. During reset all my warning lights on my dash came on and part of the H.U.D. unit started to melt. Took it off and now my check engine light stays on. I hope it just needs to be reset. Asking seller for a refund.
Old Aug 10, 2010 | 07:10 PM
That's too bad. You were following their verbal, so at least that part is good.
Try a 30min battery disconnect [- first then +] reconnect in reverse order. If all is good the CEL should clear in 3 engine/drive cycles. If not something is up.
Old Aug 10, 2010 | 10:19 PM
dll932's Avatar
OUCH! Please, keep us posted.
Old Aug 11, 2010 | 04:20 PM
sevenaprils's Avatar
Was this in a GD or GE?
Old Aug 11, 2010 | 05:16 PM
FITrunner's Avatar
Meh. Cool gadget but more of a gimmick. Yeah it saves you from having to look down, but really, you should be looking straight ahead anyway as opposed to looking down. If you notice that you seem to be passing people pretty easily, then you are probably speeding and might want to slow down. If you are a techno geek, then go for it. To me this is like 3D TV, nothing more that a gimmick, yeah it works, but really, does it make your TV or movie watching THAT much better, doubt it. You just believe it is so you can justify in your own mind that you spent extra $$$ for it. Not a gripe, just giving my two cents.
Old Aug 11, 2010 | 09:13 PM
dll932's Avatar
BTW, he sells another version that connects directly to the relevant sensors; less convenient, but likely safer. I can tell you me KIWI MPG won't work with a Fit, and the makers told me Honda had apparently changed the pinout of the OBD II connector (?!).
Old Aug 14, 2010 | 08:35 PM
Bohemian's Avatar
2009 base fit
Old Aug 14, 2010 | 08:37 PM
Bohemian's Avatar
Engine light went off while driving around, so hope all is good.
They are going to refund me for the unit.
Old Aug 14, 2010 | 09:14 PM
Could have been worse - glad to see it cleared. So what's next?
Old Aug 15, 2010 | 10:45 AM
Bohemian's Avatar
After seeing all my 'idiot' lights come on and the unit melt, I think I won't mess with a HUD unit. I do have a ScanGuage that is older. Probably send that in for an upgrade and find a good spot for it.
Musicalpa
Mar 18, 2025 01:06 AM
Kocho333
Oct 10, 2017 09:56 PM
JettBlackFit
Oct 9, 2014 08:00 PM
joepmac2
Dec 9, 2011 11:34 PM
ev0le
Aug 24, 2008 04:12 AM
