2007 Fit - Defective Locks!!! Absolutely NO response from Honda!
Old Nov 10, 2010 | 03:01 PM
regardner's Avatar
Angry 2007 Fit - Defective Locks!!! Absolutely NO response from Honda!
I just had to pay TWELVE HUNDRED BUCKS to replace the ignition switch & door locks on a 2007 Fit that was 48 months old.
The driver door lock & ignition locks became balky after around 28 months. I lubricated them. They were OK for a few months then the problem reoccured. The passenger door lock failed completely early this year. Last week the ignition lock failed and the car had to be towed to Honda.
The dealer did not seem surprised or interested in why 3 out of 4 locks failed after less than 4 years. Both the dealer & Honda claim these locks require no lubrication or maintenance. Honda will not say why the locks failed. The dealer seems to treat it as a normal wear item.
Honda essentially told me that they build cars to last only 3 years. Any problems due to manufacturing or design after the warranty period are not their problem. My last few cars have been Honda. I will likely never buy another. Other manufacturers seem to be more willing to stand behind their cars and build them to last more than a few years.
Ric
Old Nov 10, 2010 | 03:19 PM
gd3vbp's Avatar
Doesn't sound like these locks just failed. Sounds like something YOU did caused this. Why would you lubricate your locks? Also what did you use to lube them? Lock lube is a graphite compound...
Old Nov 10, 2010 | 03:27 PM
regardner's Avatar
I only lubricated them because I had to be able to insert the key.
Had I not, I would of had to replace them much earlier. Which would
have been better as they would of been under warranty.
I used both WD-40 & graphite. One of my peeves is that Honda will
not provide info about what to lubricate them with.
Old Nov 10, 2010 | 05:08 PM
gd3vbp's Avatar
Why are you using the key to unlock the doors? Also Honda sells a product called Lock Lube...
Old Nov 10, 2010 | 05:26 PM
Antpwny's Avatar
Sounds like the lube you use in your door locks got into the ignition lock and screwed things up. Sorry to hear man =/
Old Nov 10, 2010 | 05:48 PM
whaap's Avatar
Once something is out of warranty I can't think of any manufacturers that will just give you something out of the goodness of their heart. They're business people.
dongetti
Jan 22, 2024 10:05 AM
dhoran
Sep 29, 2020 09:28 PM
Ernie Hartt
May 31, 2011 06:18 PM
mtunofun
Jan 19, 2010 01:59 PM
rye guy
Jul 23, 2005 09:22 PM
