Sponsored by:
Sponsored by: CARiD
Replacement Battery?
Old Dec 10, 2010 | 12:59 AM
lnmcmahan's Avatar
Hi folks,
I have a 2007 Fit Sport which I use as a commuter, and which I love, but the one thing I don't love is the anemic battery. I hypermile, and it puts a pretty high load on the battery, so my first battery only lasted a little over 2 years, and an OEM replacement battery from Honda is beginning to show signs of weakness already. Even though I hook it up to a trickle charger in the garage almost every night. Is there a high amp-hr replacement for the OEM battery? If there is, I would like to buy one. Has anyone modified the battery holder to take a larger battery.
Please respond via email as well as on forum. l dot mcmahan at comcast dot net. (that first letter is a lower case L)
Thanks,
Larry
Old Dec 10, 2010 | 01:53 AM
fit2bking's Avatar
you can stick a yellow optima battery in there, they have a 51r 450cca.
Or an interstate megatron 500cca.
Old Dec 12, 2010 | 01:30 AM
KI_GSE21's Avatar
You can get the Everstart or Energizer from your nearest Walmart. They are made by the same company, called Johnson Controls. They usually have better cold cranking amps than OEM battery specs.
Old Dec 12, 2010 | 07:39 PM
spreadhead's Avatar
Any 51R will fit, no mod needed.
Old Dec 12, 2010 | 07:48 PM
DiamondStarMonsters's Avatar
Optima Deep Cycle Yellow Top Battery (Group Size-51R) - INSSC51RDA
Old Dec 17, 2010 | 01:21 AM
codenamezero's Avatar
Anyone know other smaller battery with enough cranking power to power up the Fit?
LLLC1393
Jan 22, 2025 08:46 AM
Jensen Healy
Dec 6, 2019 02:54 PM
HKDM808
Oct 18, 2012 06:24 PM
Marrk
Mar 22, 2011 12:18 PM
SSM0423
Mar 4, 2008 08:13 AM
