Relocate Amp 2009 Fit Sport
Old Jul 6, 2011 | 02:19 PM
graykyle's Avatar
Hello all,
I just picked up a 2009 Fit Sport yesterday, and I'm enjoying the car quite a bit.
The guy I bought it from had replaced the speakers, and put in a Kicker DX 200.4 amp. He said he had it installed at Fry's, and they mounted the amp to the back of the back seat.
I think it sounds good, certainly better than stock, but I'd like to get it out of the way for when seats are down. Plus I plan on ordering Clazzios for the car, and I think the amp would obstruct them.
I don't want to take out the spare, so I'm trying to figure out where I could feasibly mount this, so it's out of the way of any cargo storage. I don't mind undertaking the task myself, but I'm not sure where it can feasibly go.
The dimensions are listed as: 10-1/4" X 8-5/16" X 2-1/8"
I want to do a few other things with the Fit, but this is number one.
I would greatly appreciate any feedback, and do apologize in advance if I've overlooked threads that spell this out for me.
Thanks,
Kyle
Old Jul 6, 2011 | 06:48 PM
lashlee's Avatar
I don't know if the GE has any room like the GD but there might be enough room to mount it behind the panel on the passenger side. It would be difficult to get to for adjustments and it may run hot but it would be out of the way. You also could look if it will fit inside the spare tire, but you may run into trouble if you ever have a flat. With a little effort you could make some quick disconnects and make it removable.
Old Jul 6, 2011 | 07:16 PM
specboy's Avatar
If you aren't bad with a hammer or Saw, you could replace the trunk floor with a slightly raised MDF floor that the amp could sit under. Make sure there's a few Vent holes or put a grate in with a small fan.
~SB
Old Jul 6, 2011 | 08:38 PM
graykyle's Avatar
Thanks for both ideas. I'm not handy enough with hammer and saw to build anything like that, but thanks for the idea Specboy.
I'd really like to keep it out of the spare, as I'd really like to keep the spare in there.
The door option sounds pretty intense as well, but something I'll look into.
Does GE (generation E) refer to 2009+?
Thanks guys,
Kyle
Old Jul 7, 2011 | 12:03 AM
LeafEater's Avatar
it seems like the amp might be small enough to fit into the spare tire. you could buy a small piece of 1/2"-3/8" thick plywood and mount it upside down in the spare tire. you might have to remove those 4 small pieces of foam that touch the tire to make the plywood fit, you may also have to cut it.. Honestly i think that is your best option to get it out of sight and out of the way.
^ this option keeps the spare tire intact and in the car. Try test fitting the amp upside down and into the spare tire's diameter.
Old Jul 7, 2011 | 12:15 AM
graykyle's Avatar
This is another interesting idea, but it sounds more feasible for me to be able to actually do, and it's not too far (distance wise) from where the amp resides now.
I'll go dig around in there and see what the spacing looks like. If it's mounted securely enough, I imagine it would be stable enough.
Thanks for the idea, will report back.
-Kyle
Old Jul 7, 2011 | 12:33 AM
graykyle's Avatar
Just found this thread that goes into what LeafEater is talking about.
https://www.fitfreak.net/forums/2nd-...ml#post1010594
It also makes me better understand SpecBoy's mdf floor idea, which in theory doesn't sound that difficult. Plus I have the rubber tray. I just don't have the tools to cut out a new floor, though it sounds like a sturdy pretty painless idea.
Old Jul 8, 2011 | 10:30 AM
graykyle's Avatar
Yesterday I bought some bolts, washers, and nuts for $1.30, then re-mounted the amp to the underside of spare tire cover. After everything was attached, I felt very confident that it was secure. It also didn't feel too heavy for the cover either.
I'm content with the amp hidden away, and can now throw some Clazzios in
-Kyle
ck42
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
13
Jul 14, 2017 12:11 PM
raton
Dec 25, 2010 04:21 PM
OhNineFIT
Oct 16, 2010 10:59 AM
accordguyintake
Jan 26, 2010 02:54 PM
arsonall
Dec 11, 2006 05:29 AM
