Not the blower motor resistor..08 FIT SPORT
Old Jul 7, 2011 | 06:49 PM
johnnyvirgil's Avatar
I did a search here for blower motor problems and it appears that most are of the "only works at top speed" issue. Mine's a little different. All speed works, but 3 and 4 sound like the fan motor is trying to shake its way out of the dashboard. I pulled the glove box, and I can feel the blower casing and when it's on 3 or 4 it vibrates like crazy, vibrating everything in the car with it. Does anyone know if this is a common issue? I'm just out of warranty (of course) but I'm wondering if I should just order replacement parts now, or if there's a way to fix the one that's in there. Thanks!
Old Jul 7, 2011 | 09:23 PM
Perrenoud Fit's Avatar
If your mechanically inclined pull it and see what shape the bearings are in.Check the cabin filter, or it could be something in the blower wheel? But blowers usally run forever I would check the price @ the stealership but look eleswhere for a replacement. Ebay has them for 50.00 new average price, check this out:
All Categories
And type in "Honda Fit blower motor".
Old Jul 7, 2011 | 09:28 PM
That's almost what it seems like. As if the wheel is off center for some reason. At speeds 1 and 2, I can still feel a vibration, but it's not bad. Just a slight thrumming...but when it cranks up, it's ridiculous. It is hard to hear the radio it's so loud. I was going to try to take it out...I'm mechanically inclined, however, I've never done a blower before.
Old Jul 8, 2011 | 08:11 PM
Demon Fit's Avatar
That's gotta be annoying... I've never heard of any fit's having this issue before... Good luck with it man.
Old Jul 10, 2011 | 11:38 AM
Well that was easy. After I dropped the under-dash cover, the blower motor was right there. one quick connector and 3 torx screws and it was down. Too bad I had a replacement shipped overnight - I'm not going to need it.
When I looked at the fan, I found a 1/2 of an acorn jammed in the squirrel cage blade. Light enough not to matter at the low speeds, but caused all sorts of out of balance at the higher speeds. Pulled that out of there, put it back in and it's working great.
Old Jul 10, 2011 | 02:09 PM
Hey can brother ya spare an acorn?
Darn hobo squirrels
Can I get a ride to the nearest forrest?
valk97
164
Jan 9, 2025 05:06 PM
Dizzy5
Feb 22, 2018 09:23 PM
Seanhan
Dec 6, 2016 06:10 AM
bdk323
Apr 23, 2013 12:12 AM
egvtec
Dec 5, 2012 10:42 AM
