Usings a computer PSU to power a car amplifier and sub (not car related)
Old Jul 7, 2011 | 06:55 PM
Wmich5734's Avatar
I was curious if anyone knows anything about using a PSU to power a car amp and sub, so I can use it in my apartment. I've got it hooked up and it works great, but I don't know if there are any risks to using this. I haven't been able to find any threads online of people reporting potential problems of doing this. I think if I don't have it turned up too loud, I shouldn't have a problem because I wont be over working the PSU or the amp. I don't really care about the PSU, I just don't want to ruin my sub or amp. Thanks for checking this out!
Old Jul 8, 2011 | 12:10 AM
lashlee's Avatar
What I did in my shop for a test bench was an RV style of charger. I used a couple of old batteries as a buffer for the power supply. I've got a 55 amp that I've never been able to get it to break a sweat with any amp I've tested. I would think that the PSU from a computer would be weak and fail. For a little money you could do better.
Old Jul 8, 2011 | 02:08 PM
neil patrick harris's Avatar
i use one of these things:
it's 12v as well so it's the right voltage. it last about 15-30 minutes, enough time to test everything out and make sure everything is working.
as far as you using a PSU, you should be fine and it won't hurt anything. PSUs are made not to spike so your amp should be fine.
Old Jul 8, 2011 | 06:36 PM
Demon Fit's Avatar
what is a PSU?
Old Jul 11, 2011 | 06:26 PM
lashlee's Avatar
PSU is a computer power supply unit and it should work for small power situations (like powering a H/U). My biggest worry would be the voltage sag which would kill the internal power supply of the amplifier. It just seems silly to save $100 just to kill an amp and have to spend more than that to replace an amp.
short1
Aug 11, 2013 09:49 PM
ck42
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Jul 6, 2013 12:14 AM
Jaivee
SoCal Classifieds
Apr 12, 2012 04:11 AM
Vash
Nov 9, 2011 07:11 PM
gurdain
May 14, 2010 09:29 AM
